Photo-video rendering plug-in
This topic has been viewed 848745 times and has 225 replies
enkonyito
Re: Photo-video rendering plug-in
Post by enkonyito »
The source code is also available here.
EnkoNyito
enkonyito
Post by enkonyito »
PhotoVideoRendering-2.4 plug-in
As EnkoNyito is not available at the moment to update his Photo-video rendering plug-in, I made the necessary changes to this plug-in to ensure its compatibility with Sweet Home 3D 7.0 lights defined from a shape with [font=courier new]lightSourceMaterialName#[/font] property.
Note that the YafaRay rendering engine included in this plug-in doesn't work with the Mac App Store version 7.0.1 and above for security reasons, but works with the free version.
With the old YafaRay Rendering plug-in, you had to use the lib folder of the [font=courier new]com.eteks.sweethome3d.plugin.yafarayrendering[/font] package to load the necessary DLLs.
Sweet Home 3D 7.0, uses the "com.eteks.sweethome3d.j3d.YafarayPluginsFolder" system property which causes the error:
Code: Select all
Exception in thread "pool-9-thread-1" java.lang.UnsatisfiedLinkError: com.eteks.sweethome3d.j3d.AdvancedYafarayRenderer.createEnvironment(Ljava/lang/String;Ljava/lang/String;)J
	at com.eteks.sweethome3d.j3d.AdvancedYafarayRenderer.createEnvironment(Native Method)
	at com.eteks.sweethome3d.j3d.AdvancedYafarayRenderer.init(AdvancedYafarayRenderer.java:357)
	at com.eteks.sweethome3d.j3d.AdvancedYafarayRenderer.render(AdvancedYafarayRenderer.java:849)
	at com.eteks.sweethome3d.j3d.AdvancedAbstractPhotoRenderer.render(AdvancedAbstractPhotoRenderer.java:157)
EnkoNyito
Country: Paris, France
Post by Puybaret »
Sorry, I forgot to mention here that I released the version 2.4.1 to fix a bug reported by Captaincook about invisible lights which had no effect with SunFlow.
EnkoNyito, I’m not sure what you want to do or what problem you encountered. Can you explain how you got the error you reported?
enkonyito
Post by enkonyito »
In version 2.4.1, the [font=courier new]com.eteks.sweethome3d.plugin.yafarayrendering[/font] package containing the YafarayRenderer.java file is used to load the necessary DLLs.
In Sweet Home 3D 7.0, the YafarayRenderer.java file (subclass of AbstractPhotoRenderer) is contained in the [font=courier new]com.eteks.sweethome3d.j3d[/font] package.
By not including the [font=courier new]com.eteks.sweethome3d.plugin.yafarayrendering[/font] package in the plug-in and by using the new loading of the DLLs of the file YafarayRenderer.java of SH3D-7.0, we have the error above.
By opening the default photo panel first, the error returned is:
Code: Select all
java.lang.UnsatisfiedLinkError: Native Library C:\Users\user\AppData\Local\Temp\com.eteks.sweethome3d.SweetHome3D-cache-yafaray-64-43014161-1659389236\libwinpthread-1.dll already loaded in another classloader
	at java.lang.ClassLoader.loadLibrary0(Unknown Source)
	at java.lang.ClassLoader.loadLibrary(Unknown Source)
	at java.lang.Runtime.load0(Unknown Source)
	at java.lang.System.load(Unknown Source)
	at com.eteks.sweethome3d.j3d.AdvancedYafarayRenderer.<clinit>(AdvancedYafarayRenderer.java:248)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Unknown Source)
	at com.eteks.sweethome3d.j3d.AdvancedAbstractPhotoRenderer.createInstance(AdvancedAbstractPhotoRenderer.java:95)
Is it better to use the DLLs present in lib/yafaray of SweetHome3D-7.0 or in com/eteks/swethome3d/plugin/yafarayrendering/lib of the YafarayRendering-1.4.5 plugin?
EnkoNyito
Post by Puybaret »
It would be better to reuse the DLLs available in Sweet Home 3D in your plug-in, but then you'll get the error you reported. As removing these DLLs from your plug-in will prevent it to work with older versions of Sweet Home 3D, I think it's better to keep them with your plug-in for the moment.
varigonda
Country: India
Post by varigonda »
My simple photo rendering is stopping in between without showing any progress. and when i stop the rendering then save button is not visible at this time (When it is stuck).
i am using mac 10.12 , simple photo rendering 2.4.1 .
after in progressed for couple of hours then it stuck then there is no way to retrieve photo it created. need help in fixing this issue . At least can you please let me know how to retrieve photo it created till that point.
Below are setting i am using.
1) depth of field and best quality with sky light on.
2) below are advanced settings
AA_minsamples 16
lighting method sppm
normallens.radios 0.1
remaining all default settings.
YGYL
Post by YGYL »
Found a bug, when the sky box texture is set, SUNFLOW engine rendering ray tracing will become completely black
enkonyito
Post by enkonyito »
@varigonda
When you click on Stop, the Save button becomes available if rendering has stopped correctly and it is possible to save your image. If not, your rendering has terminated abnormally.
@YGYL
To use Path global illumination with a sky texture, sky lighting must be enabled.
EnkoNyito
enkonyito
Post by enkonyito »
@Puybaret
Indeed, it is more practical to keep the YafarayRendering-1.4.5 plug-in dlls otherwise it would have been necessary to create a version derived from SweetHome3D-7.0.
A question that has nothing to do. How to modify the luminosity of the sky (color or texture) as it is already the case for the ground with Java3D (3D view)?
EnkoNyito
enkonyito
Post by enkonyito »
PhotoVideoRendering-2.5 plug-in
EnkoNyito
