A Better Render
This topic has been viewed 70625 times and has 51 replies
Discuss anything here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
stef.salmon
Country: UK
Re: A Better Render
Post by stef.salmon »
Thanks for the info.
Can I not get rid of the shadows using the normal rendering engine?
Did you see what I meant in this image in the preview window?
https://www.dropbox.com/s/fzxxpr6d2oons ... 1.png?dl=0
Country: Switzerland
Re: A Better Render
Post by UbuntuBirdy »
Try quality level 1, it's the same like the preview window.
stef.salmon
Country: UK
Re: A Better Render
Just did that and it looks terrible!
I just want to remove the shadows and get it to render properly.
stef.salmon
Country: UK
Re: A Better Render
It needs to be on quality setting 4.
I can't see why it won't render properly.
stef.salmon
Country: UK
Re: A Better Render
It could be so good...but it fails at the last hurdle!
https://www.dropbox.com/s/2ez62zuxwvkrt ... 3.png?dl=0
I don't understand it.
Country: Copenhagen, Denmark
Re: A Better Render
Post by Ceciliabr »
I saw your image. The plugin is using the same renderers as the ones that comes with SH3D, it just gives you a set of options that are not included in the simplified version you get with the program. It's completely safe. Try it, and you will be amazed!
stef.salmon
Country: UK
Re: A Better Render
I did try it and it was even worse.
stef.salmon
Country: UK
Re: A Better Render
Maybe you could try it out.
https://www.dropbox.com/s/rhk7xdfmuc1yr ... .sh3d?dl=0
Thanks.
Re: A Better Render
Post by Ceciliabr »
Yes, why not...
Ok, I understand what you mean. Your models and your textures are not very good.
Work a bit on your models, and try using some light panels. It might do the trick.
Cecilia
stef.salmon
Country: UK
Re: A Better Render
Hi Cecilia,
That looks pretty good to me.
Please could you do a screenshot of the settings you used?
How did you get rid of the shadows?
The models are from Trimble 3D Warehouse...I don't know how to do models. I'm looking for some decent ones for these Data Centres that we are doing. CTG trader have some good ones but when they are imported into SH3D they lose their quality.
Do you know anyone that can do the 3D modelling of equipment?
Many thanks.
