Thank you for your tests.
Previous versions of Sweet Home 3D can all be found at http://sourceforge.net/projects/sweetho ... weetHome3D
Auto-crashing file
This topic has been viewed 16546 times and has 21 replies
Re: Auto-crashing file
Emmanuel:
Thanks you for the links. I knew I had seen this page somewhere, but I couldn't remember where.
v2.2 was downloaded the first time from the website. I deleted it and re-downloaded from Sourceforge. Again it didn't want to open at all. I have to click the "run" button, and that's where it stops.
v2.1 crashed while loading for the first time (log 7978). The second time it completed loading without a problem. The file opened with all textures correctly rendered.
v2.0 loaded the first time without problems. The file opened with all textures correctly rendered.
All these were done on my Ubuntu PC using the file db4tech loaded and saved for me (the one with all textures, not the stripped version).
Let me know if you want any further testing done.
- hs_err_pid27978.log
- (42.74 KiB) Downloaded 39117 times
