Cut out
This topic has been viewed 15900 times and has 26 replies
Country: UK
Re: Cut out
Post by Mike53 »
You may need to disable magnetism while positioning them.
stef.salmon
Country: UK
Re: Cut out
Post by stef.salmon »
Hi Mike,
If I disable magnetism I can line up the door, but it doesn't cutout the invisible box like it does on a normal wall.
Country: Paris, France
Re: Cut out
Post by Puybaret »
Invisible boxes don't cut other pieces of furniture. They only cut walls and floors as show in this tip.
stef.salmon
Country: UK
Re: Cut out
Is there a way of having a transparent wall with a door?
I have managed to put in some transparent glass walls, but now I just need to add a door which actually has a cutout.
https://www.dropbox.com/s/ec2gvrl4mr896 ... S.png?dl=0
Country: UK
Re: Cut out
Post by Mike53 »
Not sure i understand correctly, but have you thought to insert the door into a wall with its opacity set to nearly clear, then exporting both the door and the wall?
stef.salmon
Country: UK
Re: Cut out
Never tried to create an object before!
That worked a treat...thanks Mike [;)]
Country: UK
Re: Cut out
Post by Mike53 »
Thank the lord its nearly january, i only get 1 good idea a year. [:D]
