Making continues walls
This topic has been viewed 17499 times and has 28 replies
Discuss anything here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Country: Paris, France
Re: Making continues walls
Post by Puybaret »
Lumaja, did you try the solution I posted?
Post by dorin »
1. This forum is not intend to be for how to administrate various kind of linux systems. The "su" command is the classic way to become "root".
I suppose You have some kind of *buntu or *mint. You could tell me more by typing in terminal: infobash -v3
2. Anyway you could skip the part with "su" and continue with steep 2
Lumaja
Country: Newcastle, KZN, South Africa
Post by Lumaja »
Yes, and just did it again the file in .eteks Plugins are all there, made two walls in SH looking
into Plan Connect walls is not there.
Lumaja
Post by Lumaja »
I have all the extracted files of AdvancedEditing in eteks/Plugins
Thank you.
Post by dorin »
1. In a previous post I've made a mistake:
--Open an terminal (console):
--type su
--type your root password
--type mv /root/home/.eteks
--type exit & close the terminal.
Please replace mv /root/home/.eteks with rm -rf /root/home/.eteks/
2. As normal user (luis) open a terminal and type:
2.1. ls -al /home/luis/.eteks/sweethome3d/
You should have something like these:
drwxr-xr-x 8 luis luis 4096 Aug 29 13:39 .
drwxr-xr-x 3 luis luis 4096 Aug 9 2012 ..
drwxr-xr-x 2 luis luis 4096 Sep 1 08:19 furniture
drwxr-xr-x 2 luis luis 4096 Mar 31 10:39 languages
drwxr-xr-x 2 luis luis 4096 Aug 14 10:25 plugins
-rw-r--r-- 1 luis luis 16440 Aug 29 13:29 preferences.xml
drwxr-xr-x 2 luis luis 4096 Aug 29 13:31 recovery
drwxr-xr-x 2 luis luis 4096 Feb 25 2014 textures
drwxr-xr-x 2 luis luis 4096 Sep 1 08:21 work
2.2. ls -al /home/luis/.eteks/sweethome3d/plugins/
In my system I have this:
drwxr-xr-x 2 dorin dorin 4096 Aug 14 10:25 .
drwxr-xr-x 8 dorin dorin 4096 Aug 29 13:39 ..
-rw-r--r-- 1 dorin dorin 103612 Aug 7 20:46 AdvancedEditing.sh3p
-rw-r--r-- 1 dorin dorin 3849 Apr 16 19:07 calculateWalls.sh3p
-rw-r--r-- 1 dorin dorin 15632 Oct 3 2010 CopyStylePlugin.sh3p
-rw-r--r-- 1 dorin dorin 7974 Sep 7 2013 DimensionLines.jar
-rw-r--r-- 1 dorin dorin 29365 Jun 15 2009 ExportToSH3F-1.0.sh3p
-rw-r--r-- 1 dorin dorin 14949 May 24 2009 RotateHomePlugin.sh3p
-rw-r--r-- 1 dorin dorin 54536 Dec 24 2013 UtilityPlugin.sh3p
-rwxr-xr-x 1 dorin dorin 2840 Jun 8 2009 VolumePlugin.jar
That's the way my SH3D work great.
Hope this is helpful for You.
Lumaja
Post by Lumaja »
Tried ls -al /home/luis/.eteks/sweethome3d/plugins/
luis@luis-G41M-Combo:~$ ls -al /home/luis/.eteks/sweethome3d/plugins/
total 44
drwxrwxr-x 4 luis luis 4096 Sep 26 14:07 .
drwxrwxr-x 9 luis luis 4096 Sep 26 14:20 ..
-rw-rw-r-- 1 luis luis 18347 Oct 4 2006 COPYING.TXT
drwx------ 3 luis luis 4096 Sep 26 14:07 de
-rw-rw-r-- 1 luis luis 758 Jul 16 22:12 LICENSE.TXT
drwx------ 2 luis luis 4096 Sep 26 14:07 META-INF
-rw-rw-r-- 1 luis luis 789 Jul 16 22:10 README.TXT
is totally different why is this ?
Post by dorin »
You have extract the AdvancedEditingPlugin-src.zip file.
You need only the AdvancedEditing.sh3p file to be copy in plugins directory.
Solution:
1. Go in /home/luis/.eteks/sweethome3d/plugins/ and delete all.
2. Download AdvancedEditing.sh3p file and copy in plugin directory.
3. Start SH3D program.
P.S. That's how to install plugins in SH3D.
Lumaja
Post by Lumaja »
Thank you, eventually is in SH and can connect walls.
Went to see with ls -al /home/luis/.eteks/sweethome3d/plugins/
total 112
drwxrwxr-x 2 luis luis 4096 Sep 30 13:25 .
-rw-rw-r-- 1 luis luis 103612 Sep 18 09:45 AdvancedEditing.sh3p
Not the same as you get, is the difference matters?.
Post by dorin »
NO!
I have installed more plugins then You have.
Now, in menu bar of SH3D, You must find:
Menu bar Plan -> Connect walls.
To use this You must have some walls draw in plan.
Remember ALL walls have a start point and an end point.
You can connect the end point of FIRST selected wall with the start point of the SECOND selected wall.(use Shift for this).
Make some tests on a mew plan to learn how it's work.
Their is more tricks to discover like 2 clicks.
