Export to HTML5 plug-in
This topic has been viewed 4965675 times and has 152 replies
Country: Paris, France
Re: Export to HTML5 plug-in
Post by Puybaret »
I'm glad you found some use for the [font=courier new]Home.xml[/font] export. Do you plan to make your script available to the public? That would be a nice way to import a home in Blender with lights.
I don't know whether the HTML viewer will support some lighting, but you can already get in [font=courier new]Home.xml[/font] file the light information you look for by changing some flags in the plug-in source code included in the sh3p file (or reusing plug-in classes in an other plug-in). The easiest way should be to remove [font=courier new]HomeXMLFileRecorder.INCLUDE_VIEWER_DATA[/font] flag (and [font=courier new]HomeXMLFileRecorder.REDUCE_IMAGES[/font] if you don't want images to be resized) in the [font=courier new]getHomeRecorder[/font] method the end of the [font=courier new]ExportHTML5PluginAction[/font] inner class of [font=courier new]com.eteks.sweethome3d.plugin.exporthtml5.ExportHTML5Plugin[/font]. Then, rebuild the plug-in with the help of Plug-in developer's guide.
The XML format of [font=courier new]Home.xml[/font] shouldn't change in the future, it will even become part of the updated format of Sweet Home 3D files. In the coming versions 5.x, the idea is to include the [font=courier new]Home.xml[/font] file along with the existing [font=courier new]Home[/font] Java serialized entry in .sh3d files + the ability to parse both entries even if they describe the same [font=courier new]com.eteks.sweethome3d.model.Home[/font] instance. Then probably in versions 6+, the default Sweet Home 3D files will have a .sh3x extension and use a file format that will contain a [font=courier new]Home.xml[/font] entry but no [font=courier new]Home[/font] entry, to avoid slowing down Save operation. This transition will help users to read .sh3x files even with Sweet Home 3D version 5.3 and superior. Of course, the ability to read [font=courier new]Home[/font] Java serialized entry included in .sh3d files will be kept to be able to read all files made with previous versions of Sweet Home 3D.
The XML writer added to Sweet Home 3D 5.3 will be very close to the one in Export to HTML5 plug-in, using the same elements and attributes syntax when its [font=courier new]INCLUDE_VIEWER_DATA[/font] flag is not set. Why only "very close" and not "the same as"? Because the plug-in needs to simplify the exported data to match SweetHome3DJS features, i.e. its inability to read 3D models at 3DS and DAE format as well as to compute walls and rooms in 3D. Quickly said, at the moment, the plug-in is "only" able to read 3D models at OBJ+MTL format listed in [font=courier new]Home.xml[/font] and place them at the good location. Walls, floors, ceilings, holes in the ground and 3D labels are all precomputed by the plug-in in the [font=courier new]HomeStructure/Home.obj[/font] entry which is displayed as one 3D object by SweetHome3DJS. This structure file and exporting only in OBJ format is not needed in Sweet Home 3D itself, that's why its XML writer will not perform these operations but will keep the same XML syntax, except for the [font=courier new]structure[/font] attribute of the [font=courier new]home[/font].
From the various tests I run with Blender, it seems that Blender supports better OBJ+MTL format than 3DS and DAE formats (but maybe it was improved recently). Blender is of course unable to compute in 3D the walls and rooms of a Sweet Home 3D file. So I guess that the format I chose for SweetHome3DJS is the best choice for Blender too, and you would prefer that the way 3D models and home structure are exported won't change! I'll keep that in mind and if needed I'll create an other Export to XML + OBJ plug-in. That could even become a Save option in Sweet Home 3D if this format becomes really useful for many people. Keep also in mind that DAE/Collada format is also able to store lights, so if you need only OBJ files + lights, it could be more logical to add Export to DAE format option (even if this will require more work from me).
Post by okh »
..In the coming versions 5.x, the idea is to include the Home.xml file along with the existing Home Java serialized entry in .sh3d files...
Does this mean the .sh3d file will contain all files needed by the export to html javascripts for the canvas? ok
lcgamboa
Country: Brasil
Post by lcgamboa »
Of course, I will distribute the script in GLP, when a finish it. (there are some bugs to fix yet)
I asked about lighting support in HTML viewer because the webgl has support to it. There are some nice examples of webgl lighting on the web.
Looking the plugin code, I think that remove HomeXMLFileRecorder.INCLUDE_VIEWER_DATA flag, only for HomeLight in my case, will solve the problem.
About the SweetHome3DJS and SweetHome3D XML format is exactly what had thought.
I agree that SweetHome3DJS XML format (added with the lamp color and power ) plus the obj+mtl files is the best choice for blender export.
About export in DAE/Collada format for now I think you should focus on sweethome 3d. After you import the file XML+obj+mtl in blender(or other software) they can be converted to other formats.
Thank you for the help.
Post by Puybaret »
It's one of my goals at the end, but that requires to port to JavaScript the classes DAELoader, Max3DSLoader for DAE/3DS support, and Wall3D, Room3D,Ground3D and other model classes to manage the structure of a home. Porting these 5000 lines of code will require probably two weeks of work and will avoid to use the Export to HTML5 plug-in, but without adding any new feature to the end user.
I wonder if it wouldn't be better to be able to add and arrange furniture in the plan first. This second task requires more work but would bring some nice features in SweetHome3DJS...
Post by okh »
Absolutely. But as an end goal for some time in a distant future, it would be nice if the (super great) HTML export could use standard .sh3d files. But urgent, not at all. The HTML export works very nicely as is.
Post by Puybaret »
As I received an other request similar to lcgamboa's one, I finally programmed the additional Export to XML/OBJ plug-in (see links at end of message) that proposes the Tools > Export to XML/OBJ format menu item able to generate a ZIP file that contains:
- [font=courier new]Home.xml[/font] entry with all the data of the edited home at XML format (including furniture visible or not, walls, rooms, texts, dimensions lines, polylines...)
- [font=courier new]HomeStructure/Home.obj[/font] that contains the home structure computed by Sweet Home 3D classes (wall, rooms, ground and 3D labels)
- 3D models only at OBJ+MTL format (models at other format will be converted)
- furniture icons, texture images and other images.
This generated ZIP file is compatible with Sweet Home 3D JS viewer (it just contains more data that the home file generated by Export to HTML5 plug-in, and will be readable with Sweet Home 3D 5.3 too, once the upcoming changes in .sh3d file format will be programmed.
The XML schema used in the [font=courier new]Home.xml[/font] entry should be quite straightforward. Its elements and attributes match com.eteks.sweethome3d.model API (except for the classes starting by [font=courier new]Home[/font] which is omitted, like [font=courier new]HomeLight[/font] class which becomes [font=courier new]light[/font] element). An exported Home instance will have an XML structure looking like this:
Code: Select all
<home>
  <furnitureVisibleProperty/>
  <property/>
  <environment/>
  <compass/>
  <observerCamera/>
  <camera/>
  <level/><level/>
  <pieceOfFurniture/><doorOrWindow/><light/>
  <wall/><wall/><wall/>
  <room/><room/>
  <polyline/><polyline/>
  <dimensionLine/><dimensionLine/>
  <label/>
</home>
At the moment, the only elements which have an [font=courier new]id[/font] are [font=courier new]level[/font] and [font=courier new]wall[/font] elements because they can be referenced in other elements. Lengths are in centimeters and angles in radians. If needed, look at [font=courier new]com.eteks.sweethome3d.plugin.exportxml.HomeXMLExporter[/font] class source code included in the plug-in or ask for more information in this forum. A more complete description of the schema will be available with next Sweet Home 3D release.
This plug-in reuses the same classes as Export to HTML5 plug-in, that's why it uses the same version number 1.1.
Hope you'll find all kind of use for your Sweet Home 3D data [:)]
Download links for Export to XML/OBJ plug-in:
Export to XML/OBJ plug-in 1.1 was released on 06/07/2016
Export to XML/OBJ plug-in 1.2 was released on 12/13/2016
Export to XML/OBJ plug-in 1.3 was released on 10/10/2017
Home.xml
(14.46 KiB) Downloaded 11725 times
lcgamboa
Country: Brasil
Post by lcgamboa »
Puybaret thank's for the Export to XML/OBJ plug-in!
Now I have to change my blender import script to work with the new XML schema. With the new XML the light will can be edited in Sweet Home and blender will be used only as viewer.
I published the python script to import SweetHome 3D HTML5 to blender in GitHub: SweetHome3D HTML5 to Blender importer. The script creates one object for each obj file (leaving easier editing of objects in blender), this is the the main difference to use the obj file generated by SweetHome 3D.
avamonster
Country: Russia
Post by avamonster »
Hi all,
This thing does not work in Chrome out of the box.
to run the exported ViewHome*.html in Chrome browser, you have to start chrome.exe with "--allow-file-access-from-files" commandLine option (no quotes).
Else it will just stuck on "loading model" message.
Probably it's good to add info on that to blog/manual e.t.c., or m.b. even add a message on local file access to ViewHome.html.
M.b. it's possible to somehow detect that accessing files from files is disabled right from the page script, and display corresponding message.
WBR,
AVAmonster
ersteinmal
Post by ersteinmal »
I am sorry.
But in Opera 40.0.2308.81
The Html file start to load *.zip and stops there.
Regards Carsten
Post by Puybaret »
Just tried this version of Opera under Windows 10 and Mac OS X, and I didn't notice any issue...
Did you try with another browser? Maybe your file is very big.
