Light & textures - rendering examples of this and that.
This topic has been viewed 461839 times and has 128 replies
AdeleAlli
Country: Italy
Re: Light & textures - rendering examples of this and that.
Post by AdeleAlli »
This is one more, a sea view bedroom :)
And this is the other part of the bedroom
Country: Copenhagen, Denmark
Post by Ceciliabr »
Very nice!
Seems you're getting the hang of it.
Here's a tip:
Try to scale down your background image so that the sky starts at the top of the green area of the sky template, and watch what happens.
rontant
Country: Singapore
Post by rontant »
Here is a result I obtained using your template Cecilia.
What do you think about it?
For the one with seaview, I think you placed the horizon way too high. Make sure the horizon and the distant mountain are within the green band in Cecilia's template.
AdeleAlli
Country: Italy
Post by AdeleAlli »
Very nice!
Here's a tip:
Thanks, I think now it is better :)
But the problem is that I should scale a lot the background image in order to have a large covering of the sky, and this brings a lower quality of it.
AdeleAlli
Country: Italy
Post by AdeleAlli »
Here is the result, I think it is better, thank you Rontant.
rontant
Country: Singapore
Post by rontant »
Yes, you got it. Well done. Bravo!
Post by Ceciliabr »
Seems you are using a wide angle FoV here.
Try setting the FoV to around 60 and move the camera back until you have a nice shot.
Note: you can move the camera further back to see the coordinates better. In fact you can move the camera anywhere on the x,y and z -axis, and your preview will still show exactly the same sector of the sky.
Do this again:
Look at the coordinates. Your image does not need to cover more than what's inside the coordinates, neither the width or the height.
AdeleAlli
Country: Italy
Post by AdeleAlli »
I tried to change some parameters, to adjust the virtual visitor and to scale the background image, here is the result:
Country: UK
Post by Mike53 »
Wonderful, expert, tutorial, th Cec
Post by Ceciliabr »
@ AdeleAlli
I think it's better when the horizon/sky-image is sized this, but maybe you should select a wider image, so that the horizon is covered for the full with of the snapshot.
If I could see your project file, I could make some suggestions about using the sky image.
