New prefixes
This topic has been viewed 20185 times and has 43 replies
Looking for a particular 3D model or texture? [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Country: Switzerland
Re: New prefixes
Post by UbuntuBirdy »
After Hans discovered some issues I tested them one more time - and yes, he is right:
1. (left folding chair) This issue is no problem for me, but it would be nice if we can turn the whole chair standing upright.
2. (right folding chair) Same problem as in point 1 but in a different position.
3. (right folding chair) The hinges of the back legs are "Broken". They move out of the counterpart...
alaX
Country: Poland
Re: New prefixes
Post by alaX »
@Hans
1.I agree it's not convenient and not easy to guess the angle of rotation. Let's forget about this solution.
2. Seat is not supposed to rotate - the idea was to force horizontal position for folded "legs" too. But folded chair also needs rotation, only this time it's x90degrees.
3. Yes, okh's suggestion turns out the best.
@UbuntuBirdy
3 works as I intended - can you show screenshot of these nauhty hinges?
@Emmanuel
Apparently I can't get out of my head rails and hinges [;)]
Here is something you can spin and spin...
Re: New prefixes
@UbuntuBirdy
I'll try my best:
alaX
Country: Poland
Re: New prefixes
Post by alaX »
I thought you were reffering to the third model - this is the second one. Hinges (prefixes) are hidden and in this case none of them is where long and short legs meet (visible hinge). That's why it looks bizzare - probably I should've removed visible hinges but it was quick modification of the first model. Anyway, in this test the third model wins.
Re: New prefixes
Post by okh »
..why do you need as small files as possible? Do they really slowing down your systems or even cause some problems?
I personally love as much details as possible in a object and hi-res textures...
Oh, detail is great. But even if SH3D is remarkably fast it will reach a point where model sizes will slow it down. Add a sufficient number of different trees, hedges and other high detail objects, and at some point you will notice a slowdown no matter the speed of the computer. Never mind the file-sizes. So I may accept a slight quality loss if I can reduce a model size significantly. That is just a question of balance and what you need the model for: some comparisons in thread 8292 can illustrate:
So one thing is acceptable quality loss. But in many cases it is also possible to simplify a model without any quality loss at all. So in general, using small but detailed models is ideal. A clever model has good detail, but is still small in size and no extra clutter that causes extra fan noise.
alaX' models are already tidy and neat, so the point I was trying to make here was a bit different. When editing the .obj file, i.e. to add hinges and rails, it is (slightly) easier with a cleaned .obj file. But I am not suggesting a quality loss. And it really is just a question of how you work with models. I guess everyone is different.
Re: New prefixes
I beleve you're right, but I have never noticed any slowing down except while loading a project. Do you have an example file for me?
Seems my projects are not detailed enough... [:-?]
You're also right about your 3 examples, if I have the possibility to choice the middle one I would do so. But what's the difference in file size between 2 and 3? Is it worth to invest more time in this model? This is another question of balance...
Re: New prefixes
Post by okh »
...difference in file size between 2 and 3?
I cannot remember the details, and do not think I saved the test files, but the difference in size is significant. Of course, there may be good reasons to use very high-res images and models. But not always. Point of the Tin can thread 8292 , was just to show an example of how far it is possible to go in vertices. I think Cec' may have done some rendeering speed tests too in the same thread (or elsewhere). What you could do, is taking your barge hull and do a limited dissolve with Blender. My bet is that you could bring it far down without any noticable difference in display quality. That should give you a good indication.
Re: New prefixes
And this is right where it is not worth the time because I do absolutely not know how to use Blender...
But I am sure you are right and if I will ever have performance problems with big models, I will remeber your words!
Re: New prefixes
Post by okh »
Great lamp in SF 3d models 505, alaX!
Some more fun and games with hinges in SF 3d models 506 - a flagpole with hinged flag. You could of course turn the flag-pole, but not without turning and misplacing the foundation. Hmm, maybe not very useful [:)]
flagpole_hinge.zip
Image Image
Re: New prefixes
Of course it is! Because the center point of the flag with pole is NOT the center point of the pole.
I had this issue with an wind turbine and I remodeled the turbine the way that the center point matches to its mast.
Your solution is way easyer and smarter!
