A Better Render
This topic has been viewed 70587 times and has 51 replies
Discuss anything here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Country: Copenhagen, Denmark
Re: A Better Render
Post by Ceciliabr »
Please could you do a screenshot of the settings you used?
Of course :
I also did some small changes to your models.
You can find the modified project file HERE
stef.salmon
Country: UK
Re: A Better Render
Post by stef.salmon »
Hi Cecilia,
Thank you so much for doing this I really appreciate it.
I just rendered it myself and it looks great. Will these settings work every time?
I'd be interested to know how you changed the models?
Many thanks, Stef
Re: A Better Render
Post by Ceciliabr »
When you open the project file I linked to, you can see what I have done if you open [font=courier new]Modify[/font] on your models:
All the [font=courier new]edge color [/font] instances have been set to [font=courier new]Invisible[/font]. Sketchup models are a bit messy and need to be cleaned.
My settings are quite universal, and will often render a nice image.
If you open [font=courier new]Modify 3D view[/font] , you will see that I have added a white solid texture to the sky.
When selecting [font=courier new]Enable sky lighting[/font] , you actually enable the sky to act as a source for image based lighting (IBL).
You could have a look at THIS THREAD if you want to read more about IBL.
You might also find some useful discussions and examples HERE.
Cecilia
stef.salmon
Country: UK
Re: A Better Render
Hi Cecilia,
I can see what you've done with the models.
I tried the same settings on another project and once again I have some weird shading on the Data Racks - See image (what would cause this)?
https://www.dropbox.com/s/tnzv7aiba4nvr ... S.png?dl=0
I created a white PNG 1000px x 1000px which I used for the floor and the sky but not sure if that's correct or the right size?
I have included the link to the project below.
https://www.dropbox.com/s/dqzt7l7lzylp4 ... .sh3d?dl=0
Sorry to keep asking all these questions and thank you so much for your help on this.
Stef
Re: A Better Render
Post by Ceciliabr »
I will have a look at it to night.
Country: Paris, France
Re: A Better Render
Post by Puybaret »
As said before, these weird images are because of back faces in DAE / Collada files.
Hide their material as you did for edges.
stef.salmon
Country: UK
Re: A Better Render
If I make the back invisible nothing happens and if I make the front invisible then the detail disappears totally.
https://www.dropbox.com/s/fzxxpr6d2oons ... 1.png?dl=0
How is doing this supposed to make any difference?
Re: A Better Render
Post by Puybaret »
Hiding the back faces won't show any difference in the 3D view or at the two lowest quality levels.
stef.salmon
Country: UK
Re: A Better Render
I'm using level 4 and the YafaRay rendering engine as per Cecilia's recommendation.
There is obviously something else I'm missing?
Re: A Better Render
Post by Puybaret »
The image you posted in your previous message shows the 3D view not a rendered image.
