smile 2040 : Mars Two
This topic has been viewed 332145 times and has 199 replies
Re: 2040 : Mars Two
Post by bdfd »
Here technical specifications of habitation module v2.
1900 x 1400 in Q4 without R1.3.1
If a storm occurs (I saw the movie 'The martian'), an anti-tilt system is set up.
4 cables out of the fifth floor (light gray, base of roof) and will be planted in the ground (like harpoons) ...
This module has five levels (with descent engines).
1st : Airlock and a rear cargo
2nd : technical part
3rd : living and sick bay
4th : bedrooms
5th : roof (upper airlock, antennas, parachutes, ...)
It can support 11 people ! [:)]
It is equipped with 4-wheel drive to adjust its position.
Re: 2040 : Mars Two
Post by bdfd »
D 188 : The D Day !
Departure begins...
1920 x 1024 in Q4 without R1.3.1
All 11 members of crew are aboard.
Look at simply inside MRV v2 :
4 in cockpit and 7 under head (lying 45 °).
side view
The order to come in :
The three first passengers in lower armchairs,
The next four in upper armchairs,
The two external astronauts in cockpit and finally
The chief and the pilot in last (central location)...
Red : air lock,
Grey : Dashboard,
Green : cockpit,
Blue : 7 Passengers (2 lines of 3 + 4 at different height.
Yellow : technical storage,
Dark blue : life support,
Purple (rear red) : toilets,
Rose : technical part,
Cyan : engines & tanks
Brown : main thrusters
Country: Paris, France
Re: 2040 : Mars Two
Post by Puybaret »
Passengers must be impatient to land! Good idea to use transparency for such a small space [;)]
Re: 2040 : Mars Two
Post by bdfd »
A hot moment for the crew and 30 mn after the Space center on Earth...
1024 x 800 in Q4 without R1.3.1
Heat shield is gone, like MRV the temperature descents, parachutes are open !
1920 x 1080 in Q4 without R1.3.1
Re: 2040 : Mars Two
Post by bdfd »
Slowly crew arrives on martian ground...
MartinSK
Country: Slovakia
Re: 2040 : Mars Two
Post by MartinSK »
Wow...
"hot moment picture"...looks really really great...
Re: 2040 : Mars Two
Post by bdfd »
Touch Down ! [:)]
"Hello Earth, Condor is on Mars ! "
Quicky from Hermes... [=D>] [=D>] [=D>]
30 mn later from Earth... [=D>] [=D>] [=D>]
Country: France
Re: 2040 : Mars Two
Post by VeroniQ »
Hurrah! Is the whole crew alive?
Re: 2040 : Mars Two
Post by bdfd »
Yes, but some jerseys well sweat ! [:))]
Here is the First interior view of this project. [:)]
1024 x 768 in Q4 without R1.3.1
Light is green, the second astronaut prepares his output from air lock...
Their priorities :
1. Prepare Habitation module,
2. Install Solar modules,
3. Go out the rover to take all members of crew...
Re: 2040 : Mars Two
Post by bdfd »
Here spécifications of MRV.
1900 x 1400 in Q4
O.S.S. will be detailled later.
