Pan tool in 3D and 2D view?
This topic has been viewed 224968 times and has 111 replies
Re: Pan tool in 3D and 2D view?
I sent you a video to show you how super fast zoom is working with Apple's mouse.
- Daniels118
- Advanced Member
- Country: Italy
Hi Emmanuel,
thank you for the video, it helped me understand what was going on. I've releasead a new version of the plugin which should fix the bug. unfortunately I cannot test it by myself on a macOS, I hope it works. If you still experience problems you have 2 options:
- help me debug the code;
- turn off the exponential wheel using the new settings panel available under 3D view -> Pan 3D view settings menu.[/list=a]I've also added an alternate way to pan for macOS, see below.
Summary of the changes:- Added ALT+left mouse button as an alternative to middle mouse button for panning (for macOS users)
- Added the SHIFT key support to increase the speed of the scroll wheel in the 3D view
- Improved exponential mouse wheel
- Implemented a limit for the max distance when moving backward with the scroll wheel
- Fixed the behavior in virtual visitor mode when custom mouse handlers wish to prevent camera rotation (1)
- Added a preferences panel to:
- enable/disable exponential mouse wheel
- enable/disable select transparent walls with mouse
Download from here: Pan3dView-2.0.sh3p
I confirm it works correctly now with Apple's mouse. Thanks [:)]
Yes it does make sense, because for some reason the center that are supposed to be rotating around, is not in the center of the screen. I my case this rotation center too much on the right side of the screen
- Daniels118
- Advanced Member
- Country: Italy
New version released!
This version brings new features and will be required for the next release of Wirings and 3D dimension lines plugins.
Summary of changes:
Summary of changes:
- Fixed a bug reintroduced in the previous release (originally fixed in 1.8)
- Fixed the polyline editing bug occurring after switching from virtual visitor to aerial view
- Implemented the edit selection with double click in the 3D view
- Implemented the delete selection with DEL key in 3D view
- Replaced the MouseHandler class with MouseAdapter class in the public API
- Daniels118
- Advanced Member
- Country: Italy
The version 3.1 allows to toggle object selection in 3D view using SHIFT key + left mouse button, so multiple objects can be selected directly from the 3D view.
This enhancement will help a lot with the automatic wiring feature that will be added to the Wirings plugin very soon.
Download from SourceForge or using the Plugin manager.
- Daniels118
- Advanced Member
- Country: Italy
Version 3.2.1 (formerly 3.2b) adds the capability to modify openings and mannequin pose directly in the 3D view!
See it in action!
Notice: this is intended only for space analysis. The changes are temporary, they will be lost if you modify the furniture and when reopening the file.
See it in action!
Soulbrother
- Member
PLEASE help.
I cannot work properly with that, so I need to deinstall, but HOW TO??
Windows 10 - SH3D 6.6a
Already tried a new installation of sh3d, but it is still the same behaviour, I cannot navigate in the 3D window as before (before installation of that "tool")
- Daniels118
- Advanced Member
- Country: Italy
I'm really sorry to hear that.
To unistall a plugin close SweetHome3D, go to "C:\Users\your_user_name\eTeks\Sweet Home 3D\plugins" and delete the plugin file.
If you wish to make it work maybe you could describe which behaviour you experience that prevent you from work.
Soulbrother
- Member
Oh, thanks a lot for your fast answer!
The behaviour is button. but using your tool drives me crazy, because if I click the right mouse button and push the mouse, it fine and I can use it - same as before.
But everytime when I click the left mousebutton and push the mouse only 0,5mm on my table, the 3D view is completely turned over and I need to use one of my saved camera-positions to be able to come back to the same view-point...
For me it would be fine, if left and right buttons could be changed ( but only for this pan-tool, not generally in windows)
But I guess it´s on me, because no other has written such a "problem"
