YafaRay rendering plug-in
This topic has been viewed 532539 times and has 172 replies
Re: YafaRay rendering plug-in
I just tried these plugin but it generates only complete grey pictures. Have I to do more than copying the file in the plugin folder?
enkonyito, did you export and load all the YafaRay DLLs required for the plug-in, like in the [font=courier new]loadDLLs[/font] method I programmed in [font=courier new]YafarayRenderer[/font] class?
jjocsak, the current version of the plug-in can work only in 64 bit. Maybe you installed Sweet Home 3D in 32 bit? If it's the case, just relaunch the installer and select the 64 bit architecture in the screen that allows to choose the installation folder. Of course, this will be possible only if your system is 64 bit.
MichaelN, did you try with some other files, or maybe the demos?
I tried it with my own file, not with the demo file.
I now tried an aother position, which works fine. Than I go again back to my kitchen - other view than before - and SH3D crashes without any message. It just disappears from the desktop.
64 bit install solved the problem, thanks.
Yes, otherwise it causes the error [font=courier new]java.lang.ExceptionInInitializerError[/font] .enkonyito, did you export and load all the YafaRay DLLs required for the plug-in, like in the [font=courier new]loadDLLs[/font] method I programmed in [font=courier new]YafarayRenderer[/font] class?
What would prevent access to native methods in this case ([font=courier new]java.lang.UnsatisfiedLinkError[/font] ) ?
EnkoNyito
Enkonyito, if you moved [font=courier new]native[/font] methods to another class or package, you'll have to generate new [font=courier new].h[/font] and [font=courier new].cpp[/font] files and compile source code to update [font=courier new]libyafarayjni.dll[/font]. Did you succeed to generate such a DLL?
As this solution (#2) works, I have not retested since.Enkonyito, if you moved [font=courier new]native[/font] methods to another class or package, you'll have to generate new [font=courier new].h[/font] and [font=courier new].cpp[/font] files and compile source code to update [font=courier new]libyafarayjni.dll[/font]. Did you succeed to generate such a DLL?
I had failed to generate the DLLs in a custom package (betaTestPlugin) when trying to follow this method:
Code: Select all
// To generate JNI DLL for Windows, read "YafaRay Windows 10 MinGW 64bit building - Standalone.txt" in Core-3.3.0\building (no need to install Python and stop after installing LIBRARY DEPENDENCIES)
// Run C:\mingw64\mingw64-shell.exe and use the following command (/C/Program Files/Java/jdk1.8.0_121 contains JDK)
// plugin project folder> g++.exe -D_GLIBCXX_USE_CXX11_ABI=0 -I"/C:\Program Files\Java\jdk1.8.0_201\include" -I"/C/Program Files/Java/jdk1.8.0_201/include/win32" -Isrc/[b]betaTestPlugin[/b]/include/yafaray -Isrc/[b]betaTestPlugin[/b]/include/other -I/C/msys64/mingw64/include src/[b]betaTestPlugin[/b]/YafarayRenderer.cpp -shared -o src/[b]betaTestPlugin[/b]/lib/windows/x64/libyafarayjni.dll -Lsrc/[b]betaTestPlugin[/b]/lib/windows/x64 -llibyafaray_v3_coreEnkoNyito
Feedback on the light panels.Some suggestions for the next version (1.0 Beta 4):
- use a YafarayRenderer.properties file to modify rendering parameters such as for SunflowRender.properties
- include an example xml scene using arealights or visible spherelights because their implementation is problematic
- make tile borders visible to see the number of rendering threads
Enko
* When I choose,
Code: Select all
params.put("type", "arealight");
// Uses the YafaRay coordinate system (X-right, Y-back, Z-up)
// vertex0 = (0% lightWidth, 0% lightDepth, 0% lightHeight)
// vertex1 = (100% lightWidth, 0% lightDepth, 0% lightHeight)
// vertex2 = (100% lightWidth, 0% lightDepth, 100% lightHeight)
// vertex3 = (0% lightWidth, 0% lightDepth, 100% lightHeight)
Point3f vertex0Location = new Point3f(0.0f - 0.5f, 0.0f - 0.5f, 0.5f - 0.0f);
Point3f vertex1Location = new Point3f(1.0f - 0.5f, 0.0f - 0.5f, 0.5f - 0.0f);
Point3f vertex3Location = new Point3f(0.0f - 0.5f, 0.0f - 0.5f, 0.5f - 1.0f);
lightTransform.transform(vertex0Location);
lightTransform.transform(vertex1Location);
lightTransform.transform(vertex3Location);
Point3f corner = new Point3f(vertex0Location.getX(), -vertex0Location.getZ(), vertex0Location.getY());
Point3f point1 = new Point3f(vertex1Location.getX(), -vertex1Location.getZ(), vertex1Location.getY());
Point3f point2 = new Point3f(vertex3Location.getX(), -vertex3Location.getZ(), vertex3Location.getY());
params.put("corner", corner);
params.put("point1", point1);
params.put("point2", point2);
params.put("color", new float [] {
((lightColor >> 16) & 0xFF) * ((this.homeLightColor >> 16) & 0xFF),
((lightColor >> 8) & 0xFF) * ((this.homeLightColor >> 8) & 0xFF),
(lightColor & 0xFF) * (this.homeLightColor & 0xFF), 1});
params.put("power", power * 100);
params.put("samples", 4);
createLight(UUID.randomUUID().toString(), params);* When I choose,
Code: Select all
params.put("type", "meshlight");
params.put("double_sided", false);
params.put("light_enabled", true);
createLight(UUID.randomUUID().toString(), params);EnkoNyito
For various reasons, I wanted to be able to recompile YafaRay DLLs. I succeeded to achieve this task without big problems under Windows and Linux thanks to the instructions given in YafaRay source code, but I had much more difficulties to make it work under macOS!
Finally, I was able to generate new DLLs based on a slightly modified version of the current source code (to fix an issue on normals management) and I'm happy to propose a version 1.0 Beta 4.
This new version is much smaller (13 MB instead of 46 MB) and should work under more systems.
enkonyito, before I investigate your problem, could you try again with this new version fist?
Happy New Year 2020 to everyone [:)]
With the YafaRay Blender-Exporter, I was able to find examples of XML scenes using different types of light.
1. No light emitted for arealight.
Example of implementation. I think it's related to line 84 of the arealight.cc file even for double sided panels.
2. Identifier not taken into account for spherelight and arealight.
To make the sphere or area lights visible, add returns the error "[font=courier new]Invalid object ID given![/font]".
How to find this identifier after the creation of the object (mesh)?
3. SH3D crash for meshlight.
These portions of code are implemented in the [font=courier new]exportLightSource[/font] method of the [font=courier new]YafarayRenderer[/font] class.
With this version 1.0 Beta 4, the following three problems occur again.enkonyito, before I investigate your problem, could you try again with this new version fist?
Code: Select all
Point3f corner = new Point3f(-100, -100, 100);
Point3f point1 = new Point3f(-100, 100, 100);
Point3f point2 = new Point3f(100, -100, 100);
params.put("from", new float [] {0, 0, 100});
params.put("power", power);
createLight(UUID.randomUUID().toString(), params);2. Identifier not taken into account for spherelight and arealight.
Code: Select all
params.put("object", id);How to find this identifier after the creation of the object (mesh)?
Code: Select all
params.put("object", 1);
