Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: obj Transparency? » » » » Post: Re: obj Transparency? |
Print at Oct 6, 2026, 1:30:00 AM |
| Posted by okh at May 21, 2014, 8:17:40 PM |
Re: obj Transparency? Hi Pencilart, I have not noticed any wrong interpretation of transparency values in sh3d. Not obj/mtl interpretation, not texture interpretation. 1) did you check the .mtl file that accompanies the .obj file? Correct transparency should be set as d value under the transparent material. Eg. d 0.0 (=fully transparent - invisible)2) did you check the texture file (if you use one - png/gif) to see whether it still has transparency after export? ok |
Current timezone is GMT Oct 6, 2026, 1:30:00 AM |
