Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to color walls? |
| Print at Sep 26, 2026, 9:32:39 AM |
| Posted by peng1 at Apr 10, 2025, 1:25:03 AM |
Re: How to color walls? At this time, you can remove color only with an undo operation. But the default color is just white with a dark grey ambiant color. If you choose a grey color, you should obtain the same effect. In case a search also leads someone else here looking for an answer to 'How do I reset the wall colour back to default?'. My work around is to click the 'Texture' button (but don't set any texture) and then 'OK'. |
Current timezone is GMT Sep 26, 2026, 9:32:39 AM |
