Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SH3D on Ubuntu 20.04 LTS |
| Print at Sep 29, 2026, 9:55:08 PM |
| Posted by DerekvG at Oct 29, 2020, 11:57:52 PM |
Re: SH3D on Ubuntu 20.04 LTS You helped me, very much, but i think it's good practise to give feedback when it's solved, so when people read the issue they may get an idea how to solve it In this case yout comments showed i needed to look elsewhere for the problem |
| Posted by UbuntuBirdy at Oct 30, 2020, 9:41:34 AM |
Re: SH3D on Ubuntu 20.04 LTS Yes, I agree! It's absolutely important, that you tell us not only that your issue is solved, but how you have solved it! Thanks for that! ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by TechnoTarzan at May 31, 2024, 7:15:14 PM |
Re: SH3D on Ubuntu 20.04 LTS Hola! I am jumping into this thread because I have a similar problem, but being somewhat of a n00b to Ubuntu, I am having difficulty following along. I am running 24.04 LTS 64-bit on Gnome 46 with Wayland. If you need more details just ask.... My problem is similar when I launch the icon from Nautilus, I right click and Run and it launches the SH3D-7.4 but terminal displays: ~/Downloads/SweetHome3D-7.4$ ./SweetHome3D Gtk-Message: 11:49:42.052: Failed to load module "appmenu-gtk-module" Gtk-Message: 11:49:42.057: Failed to load module "canberra-gtk-module" Any advice is appreciated. Thanks for your work on this app! Going to layout a small house for my daughter. |
| Posted by TechnoTarzan at Jun 1, 2024, 7:27:51 PM |
Re: SH3D on Ubuntu 20.04 LTS UPDATE: I was able to remove teh errors above by using these: sudo apt-get install libcanberra-gtk-module sudo ln -s /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libcanberra-gtk-module.so /usr/lib/libcanberra-gtk-module.so sudo apt install appmenu-gtk2-module sudo apt install appmenu-gtk3-module When I execute the icon in the SH3D folder, it executes but terminal still loads and the instant I click on FILE to start any task, I get this message: ** (java:81951): WARNING **: 12:25:31.677: Invalid borders specified for theme pixmap: /usr/share/themes/Breeze/gtk-2.0/../assets/line-h.png, borders don't fit within the image ** (java:81951): WARNING **: 12:25:31.677: invalid source position for vertical gradient ** (java:81951): WARNING **: 12:25:31.677: invalid source position for vertical gradient ** (java:81951): WARNING **: 12:25:31.678: invalid source position for vertical gradient ** (java:81951): WARNING **: 12:25:31.678: invalid source position for vertical gradient Hopefully someone has seen this before and help me get up and going? |
Current timezone is GMT Sep 29, 2026, 9:55:08 PM |
