Print at Sep 27, 2026, 6:14:42 AM
Posts: 339   Pages: 34   [ Previous Page | 22 23 24 25 26 27 28 29 30 31 | Next Page ]
Posted by byDMA at Jun 17, 2024, 11:56:07 PM
Re: Generate roof plugin
So, that is the raster plan:
If I'm wrong let me know.
Try this:
Mac may be not correct, we will correct this later. Its experimental (replace the lines for layout):
* Layout user interface
* @author Daniels118 & byDMA
protected JPanel createUI() {
JPanel roofPanel = SwingTools.createTitledPanel(null);
roofPanel.setBorder(null);
// Column 0~3 Row 0~9
roofPanel.add(roofPreview,
new GridBagConstraints(0, 0, 4, 9, 1, 1, GridBagConstraints.LINE_START, GridBagConstraints.BOTH, new Insets(0, 0, 0, 0), 0, 0));
// Column 4 Row 1
if (OperatingSystem.isMacOSX()) {
roofPanel.add(edgesLabel,
new GridBagConstraints(4, 0, 2, 1, 0, 0, GridBagConstraints.LINE_START, GridBagConstraints.NONE, new Insets(0, 10, 0, 0), 0, 0));
// Column 4+5 Row 0~7
roofPanel.add(scrollEdgesPane,
new GridBagConstraints(4, 0, 2, 7, 0, 0, GridBagConstraints.NORTH, GridBagConstraints.BOTH, new Insets(0, 0, 0, 0), 0, 0));
// Column 4+5 Row 9
roofPanel.add(resetButton,
new GridBagConstraints(4, 9, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
roofPanel.add(invisibilityLabel,
new GridBagConstraints(5, 1, 1, 1, 0, 0, GridBagConstraints.LINE_START, GridBagConstraints.HORIZONTAL, new Insets(0, 10, 0, 0), 0, 0));
// Column 6+7 Row 0
roofPanel.add(invisibilityPane,
new GridBagConstraints(6, 0, 2, 1, 0, 0, GridBagConstraints.NORTH, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 6+7 Row 1~5
roofPanel.add(faceAngleSlider,
new GridBagConstraints(6, 1, 2, 5, 0, 1, GridBagConstraints.LINE_START, GridBagConstraints.BOTH, new Insets(0, 0, 0, 0), 0, 0));
// Column 6+7 Row 6
roofPanel.add(finePane,
new GridBagConstraints(6, 6, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 4+5 Row 7
roofPanel.add(thickPane,
new GridBagConstraints(4, 7, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 6+7 Row 7
roofPanel.add(elevationPane,
new GridBagConstraints(6, 7, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 6+7 Row 8
roofPanel.add(creatorPane,
new GridBagConstraints(6, 8, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 0 Row 9
roofPanel.add(showHome,
new GridBagConstraints(0, 9, 1, 1, 1, 0, GridBagConstraints.LINE_START, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 2 Row 9
roofPanel.add(showTexture,
new GridBagConstraints(2, 9, 1, 1, 0, 0, GridBagConstraints.LINE_END, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 3 Row 9
roofPanel.add(reverseFaces,
new GridBagConstraints(3, 9, 1, 1, 0, 0, GridBagConstraints.LINE_END, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 4+5 Row 8
roofPanel.add(bordersPane,
new GridBagConstraints(4, 8, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
// Column 6+7 Row 9
roofPanel.add(aboutButton,
new GridBagConstraints(6, 9, 2, 1, 0, 0, GridBagConstraints.EAST, GridBagConstraints.NONE, new Insets(0, 0, 0, 0), 0, 0));
// First refresh roof
edgesList.updateUI();
plugin.refreshRoof(plugin.homeView, plugin.resource);
return roofPanel;
Posted by byDMA at Jun 18, 2024, 12:17:14 AM
Buttons (Reset and About) are not corect in center, we make it later, show me than the window.
Posted by dorin at Jun 19, 2024, 10:17:56 AM
Sorry for the late reaction. I have a big cervical pain for a week and it doesn't stop yet.
Your new arrangement look like this:
<DMA-01>
<DMA-02>
Some comments:
1. The single thing I've do was to add 2 spaces after the degree sign to make it more legible and increase the edge field (red arrow on DMA-01)
2. As you can see, to add extra rows don't change (improve) the aspect. The grid don't have a fixed size.
3. I've also used the Deutsch translations to show you how to different LaF render it.(red ellipses).
3.1. The truncated long text it's an old problem.
3.2. I'm curious how other applications have solve this in germane (LO, Blender, LibreCAD etc)
3.3. My solution was to find words as short as possible to use in titles and add some Tool tips with a large description.(eg. Thick in place of Thicknesses)
3.3.1 This has to be the translators task. For sample:Böschungsneigung could be replaced with Winkel or Feinjustierung with Fein
3.4. All this are necessary to keep an homogeneity between systems and their custom LaFs.
4. Some of my opinions about the ergonomy of a UI application:
4.1. Like in reading: from left to right and from top to bottom.
4.2. The most used near to top, continuing down with rarely used and finished with bottom OK or Cancel.
4.3. Almost all devices have a Reset button. Almost always is hard accessible to prevent accidental actions.
So, in my opinion, considering this, I put the Reset button on top right corner, away from used controls an Ok button.
I've thinking (from my personal experience), after a half of hour of work to fine tuning a roof to finally press Reset in place of Ok.
Well, most users probably aren't as old and stupid as me, but preemptively...
5. My arrangement also takes care of possible future improvements. (Look at the probably v5.0, if will ever be)
Posted by Puybaret at Jun 19, 2024, 10:28:30 AM
Dorin, get a good rest, Sweet Home 3D doesn’t worth that you get more pain sad
Posted by byDMA at Jun 19, 2024, 6:33:07 PM
Hi Dorin, thank you, the grids are very well.
try this and SEND me privat the compiled plugin for test.
The width of the edge panel we create with list width, not spaces.
package generateroof;
import java.awt.Color;
import java.awt.Component;
import java.awt.Dimension;
import java.awt.Event;
import java.awt.GridBagConstraints;
import java.awt.Insets;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.MouseAdapter;
import java.awt.event.MouseEvent;
import java.io.IOException;
import java.net.URLEncoder;
import java.util.HashSet;
import java.util.ResourceBundle;
import java.util.Set;
import javax.swing.AbstractAction;
import javax.swing.AbstractButton;
import javax.swing.ButtonGroup;
import javax.swing.DefaultListCellRenderer;
import javax.swing.ImageIcon;
import javax.swing.JButton;
import javax.swing.JComponent;
import javax.swing.JDialog;
import javax.swing.JLabel;
import javax.swing.JList;
import javax.swing.JOptionPane;
import javax.swing.JPanel;
import javax.swing.JRadioButton;
import javax.swing.JScrollPane;
import javax.swing.JSlider;
import javax.swing.JSpinner;
import javax.swing.JTextField;
import javax.swing.ListSelectionModel;
import javax.swing.SpinnerNumberModel;
import javax.swing.SwingUtilities;
import javax.swing.border.TitledBorder;
import javax.swing.event.ChangeEvent;
import javax.swing.event.ChangeListener;
import javax.swing.event.ListSelectionEvent;
import javax.swing.event.ListSelectionListener;
import com.eteks.sweethome3d.model.HomeMaterial;
import com.eteks.sweethome3d.model.UserPreferences;
import com.eteks.sweethome3d.swing.AutoCommitSpinner;
import com.eteks.sweethome3d.swing.ModelPreviewComponent;
import com.eteks.sweethome3d.swing.NullableCheckBox;
import com.eteks.sweethome3d.swing.NullableSpinner;
import com.eteks.sweethome3d.swing.SwingTools;
import com.eteks.sweethome3d.swing.NullableSpinner.NullableSpinnerLengthModel;
import com.eteks.sweethome3d.tools.OperatingSystem;
import com.eteks.sweethome3d.viewcontroller.HomeView;
public class GenrateRoofPluginView {
private final GenerateRoofPlugin plugin;
public GenrateRoofPluginView(GenerateRoofPlugin generateRoofPlugin) {
this.plugin = generateRoofPlugin;
float resolutionScale = SwingTools.getResolutionScale();
ModelPreviewComponent roofPreview;
ChangeListener commonListener;
ListSelectionListener edgesListener;
NullableCheckBox invisibilityCheck, showHome, showTexture, reverseFaces;
JSlider faceAngleSlider;
JRadioButton verticalBorder, orthoBorder;
ImageIcon vertIcon, vertSelIcon, orthoIcon, orthoSelIcon;
ButtonGroup borderGroupBtn;
JButton resetButton, aboutButton;
NullableSpinnerLengthModel thickModel, roofElevationModel;
NullableSpinner thick, roofElevation;
JSpinner fineSlope;
JList<SlopedEdge> edgesList;
JScrollPane scrollEdgesPane;
JTextField creator;
JLabel edgesLabel, invisibilityLabel;
JPanel invisibilityPane, slopePane, bordersPane, finePane, thickPane, elevationPane, creatorPane;
* Creates and layout the components shown in the dialog box of this plug-in.
* @param homeView
* @param resource
protected void createComponents(final HomeView homeView, final ResourceBundle resource) {
UserPreferences preferences = plugin.getUserPreferences();
String unitName = preferences.getLengthUnit().getName();
// Create a common change listener for some components.
commonListener = new ChangeListener() {
@Override
public void stateChanged(ChangeEvent ev) {
if (ev.getSource().equals(showHome)) {
if (showHome.getValue()) {
plugin.homeItems.removeAllChildren();
plugin.homeItems = plugin.createHomeNode(plugin.getHome());
plugin.refreshRoof(homeView, resource);
} else if (ev.getSource().equals(faceAngleSlider)) {
int slope = faceAngleSlider.getValue();
int maxAngle = faceAngleSlider.getMaximum() - 1;
// Limit the slope in range 1 to 179 degrees
slope = slope > 1 ? slope : 1;
slope = slope < maxAngle ? slope : maxAngle;
// Update the angle for the selected faces
for (SlopedEdge edge : edgesList.getSelectedValuesList())
edge.setSlope(slope);
fineSlope.removeChangeListener(commonListener);
fineSlope.setValue(0.0);
fineSlope.addChangeListener(commonListener);
if (!faceAngleSlider.getValueIsAdjusting() && faceAngleSlider.hasFocus()) {
plugin.updateSelectedFacesFromList(homeView, resource);
} else if (ev.getSource().equals(fineSlope)) {
// Add the fine tuning to edge slope
float fineSlopeVal = ((Number) fineSlope.getValue()).floatValue();
float angle = faceAngleSlider.getValue();
float maxAngle = faceAngleSlider.getMaximum() - 1;
float slope = angle + fineSlopeVal;
slope = slope > 1f ? slope : 1.0f;
} else if (ev.getSource().equals(invisibilityCheck)) {
if (invisibilityCheck.getValue() != null) {
boolean visible = !invisibilityCheck.getValue();
// Update the face visibility
edge.setFaceVisible(visible);
} else {
// Create edges list selection listener.
edgesListener = new ListSelectionListener() {
@Override
public void valueChanged(ListSelectionEvent ev) {
int edgeSelection = edgesList.getSelectedIndices().length;
// Limit selection to have at least one face with slope < 90 deg
int maxAngle = edgeSelection < plugin.allRoofEdges.length ? 180 : 76;
if (faceAngleSlider.getMaximum() != maxAngle)
faceAngleSlider.setMaximum(maxAngle);
SlopedEdge edge = edgesList.getSelectedValue();
if (edge != null) {
// Set angle
faceAngleSlider.removeChangeListener(commonListener);
faceAngleSlider.setValue((int) edge.getSlope());
faceAngleSlider.addChangeListener(commonListener);
// Set fine slope
fineSlope.setValue(edge.getSlope() - faceAngleSlider.getValue());
if (!ev.getValueIsAdjusting() && edgesList.hasFocus())
// Create preview
roofPreview = new ModelPreviewComponent(true, true, true, true);
roofPreview.setFocusable(false);
roofPreview.setPreferredSize(new Dimension((int) (800 * resolutionScale), (int) (600 * resolutionScale)));// @byDMA resizing window to 800x600
// Add a mouse listener to get selected faces
roofPreview.addMouseListener(new MouseAdapter() {
private Set<SlopedEdge> selectedEdges = new HashSet<SlopedEdge>();// Using a set avoids duplicates
@Override
public void mouseClicked(MouseEvent ev) {
HomeMaterial pickedMaterial = roofPreview.getPickedMaterial();
boolean sInterval = false;
if (pickedMaterial != null) {
String faceName = pickedMaterial.getName();
for (RoofFace face : plugin.faces) {
if (faceName.equals(face.getFaceName())) {
if ((ev.getModifiers() & Event.CTRL_MASK) != 0 || (ev.getModifiers() & Event.SHIFT_MASK) != 0) {
for (SlopedEdge sEdge : face.getGeneratingEdges()) {
if (!selectedEdges.add(sEdge))
selectedEdges.remove(sEdge);// Toggle selection
if ((ev.getModifiers() & Event.SHIFT_MASK) != 0)
sInterval = true;
} else {
selectedEdges.clear();
selectedEdges.add(sEdge);
break;// There can be a single face matching the picked material
int[] edgeIndices = new int[selectedEdges.size()];
int i = 0;
for (SlopedEdge sEdge : selectedEdges)
edgeIndices[i++] = sEdge.getEdge();
edgesList.setSelectedIndices(edgeIndices);
int sMin = edgesList.getMinSelectionIndex();
int sMax = edgesList.getMaxSelectionIndex();
if (sInterval)
edgesList.addSelectionInterval(sMin, sMax);
if (i > 0)
edgesList.ensureIndexIsVisible(edgeIndices[i - 1]);
} else if ((ev.getModifiers() & Event.CTRL_MASK) == 0) {
edgesList.setSelectedIndices(new int[0]);// Deselect when click the background
// String edgesLabel = resource.getString("edges.txt");// Edges: Slope
edgesList = new JList<SlopedEdge>();
edgesList.setSelectionMode(ListSelectionModel.MULTIPLE_INTERVAL_SELECTION);
edgesList.setListData(plugin.allRoofEdges);// Add edges to the list
edgesList.setCellRenderer(new EdgesCellRenderer());
edgesList.addListSelectionListener(edgesListener);
edgesList.setFixedCellWidth(140);// byDMA resize width of the List in the JScrollPane
// Put edges list into scroll panel
String edgesLab = resource.getString("edges.txt");// Edges: Slope
edgesLabel = new JLabel(edgesLab);// Edges: Slope
// scrollEdges = SwingTools.createScrollPane(edgesList);
scrollEdgesPane = new JScrollPane(edgesList);
Dimension preferredSize = scrollEdgesPane.getPreferredSize();
scrollEdgesPane.setPreferredSize(new Dimension(Math.min(200, preferredSize.width), preferredSize.height));
} else {
scrollEdgesPane.setBorder(new TitledBorder(edgesLabel.getText()));
// Create slope slider
String slopeSliderLabel = resource.getString("slope.txt");// Slope
faceAngleSlider = new JSlider(JSlider.VERTICAL, 0, 180, 40);
faceAngleSlider.setPaintTicks(true);
faceAngleSlider.setPaintLabels(true);
faceAngleSlider.setMajorTickSpacing(30);
faceAngleSlider.setMinorTickSpacing(5);
faceAngleSlider.setBorder(new TitledBorder(slopeSliderLabel));
// Create fine slope angle spinner
SpinnerNumberModel fineSlopeModel = new SpinnerNumberModel(.0, -0.9, 0.9, .1);
fineSlope = new AutoCommitSpinner(fineSlopeModel);
// Fine angle panel
String fineSlopeShort = resource.getString("fineSlope.txt");// Fine slope
finePane = SwingTools.createTitledPanel(fineSlopeShort);
finePane.add(fineSlope);
// Create face invisibility check box
String invisibility = resource.getString("invisibility.txt");// Invisible
invisibilityCheck = new NullableCheckBox(invisibility);
invisibilityCheck.setNullable(false);
invisibilityCheck.setValue(false);
invisibilityCheck.addChangeListener(commonListener);
// Invisibility check panel
String faceVisible = resource.getString("face.txt");// Face
invisibilityLabel = new JLabel(faceVisible);
invisibilityPane = SwingTools.createTitledPanel(null);
} else {
invisibilityPane = SwingTools.createTitledPanel(invisibilityLabel.getText());
invisibilityPane.add(invisibilityCheck);
// Create roof border thickness spinner
String thickLong = String.format(resource.getString("thickness.txt"), unitName);// Roof thickness
thickModel = new NullableSpinnerLengthModel(preferences, 7.6f, 2.5f, 30.5f);
thick = new NullableSpinner(thickModel);
thick.setToolTipText(thickLong);
// Thickness panel
String thickShort = String.format(resource.getString("thick.txt"), unitName);// Thick
thickPane = SwingTools.createTitledPanel(thickShort);
thickPane.add(thick);
if (plugin.isRoofSelected()) {
String sThickness = plugin.currentRoof.getProperty(GenerateRoofPlugin.ROOF_THICKNESS);
if (sThickness != null) {
float currentThick = Float.valueOf(sThickness);
try {
thickModel.setLength(currentThick);
} catch (Exception e) {
* @author Daniels118 No need to translate this message, only "hackers" have
* chances to see it
plugin.getHomeController().getView().showError("Cannot retrieve thickModel: " + e.getMessage());
thickModel.addChangeListener(commonListener);
// Create roof elevation spinner
String elevationLong = String.format(resource.getString("roofelevation.txt"), unitName);// Elevate roof at needed position
roofElevationModel = new NullableSpinnerLengthModel(preferences, 0.0f, 0.0f, 9999f);
roofElevation = new NullableSpinner(roofElevationModel);
roofElevation.setToolTipText(elevationLong);
roofElevationModel.setLength(plugin.getRoofElevation(plugin.currentLevel));
roofElevationModel.addChangeListener(commonListener);
// Elevation panel
String elevationShort = String.format(resource.getString("elevation.txt"), unitName);// Elevation(%s)
elevationPane = SwingTools.createTitledPanel(elevationShort);
elevationPane.add(roofElevation);
// Create home visibility check box
String displayHome = resource.getString("displayHomeCheckBox.txt");// Show home
showHome = new NullableCheckBox(displayHome);
showHome.setValue(false);
showHome.addChangeListener(commonListener);
// Create texture visibility check box
String useTexture = resource.getString("displayTextureCheckBox.txt");// Use roof texture
showTexture = new NullableCheckBox(useTexture);
showTexture.setValue(false);
showTexture.setEnabled(plugin.isRoofSelected());
showTexture.addChangeListener(commonListener);
// Create reverse faces check box
String reverseFacesTxt = resource.getString("reverseFaces.txt");// Reverse faces
reverseFaces = new NullableCheckBox(reverseFacesTxt);
reverseFaces.setValue(false);
reverseFaces.addChangeListener(commonListener);
// Create creator field
String author = System.getProperty("user.name");
author = plugin.currentRoof.getCreator();
creator = new JTextField(author);
creator.setEditable(true);
// @byDMA 2. store default height for TextField creator
int defaultHeight = creator.getSize().getHeight();
// @byDMA 3. set custom width and default height
creator.setSize(new Dimension(250, defaultHeight));
// Creator panel
String authorText = resource.getString("authorText.txt");// Creator
creatorPane = SwingTools.createTitledPanel(authorText);
creatorPane.add(creator);
// Create borders radio buttons
vertIcon = new ImageIcon(GenerateRoofPlugin.class.getResource("/generateroof/resources/vert.png"));
vertSelIcon = new ImageIcon(GenerateRoofPlugin.class.getResource("/generateroof/resources/vertSel.png"));
orthoIcon = new ImageIcon(GenerateRoofPlugin.class.getResource("/generateroof/resources/ortho.png"));
orthoSelIcon = new ImageIcon(GenerateRoofPlugin.class.getResource("/generateroof/resources/orthoSel.png"));
// Vertical border button
verticalBorder = new JRadioButton(vertIcon, true);// default selected
verticalBorder.setActionCommand("vertical");
verticalBorder.setSelectedIcon(vertSelIcon);
// Orthogonal border button
orthoBorder = new JRadioButton(orthoIcon);
orthoBorder.setActionCommand("orthoUp");
orthoBorder.setSelectedIcon(orthoSelIcon);
// Group border direction buttons
borderGroupBtn = new ButtonGroup();
borderGroupBtn.add(verticalBorder);
borderGroupBtn.add(orthoBorder);
// Border orientation panel
String borders = resource.getString("borderText.txt");// Border
bordersPane = SwingTools.createTitledPanel(borders);
bordersPane.add(verticalBorder, 0);
bordersPane.add(orthoBorder, 1);
// Set initial border
String dirThick = plugin.getSelectedRoof().getProperty(GenerateRoofPlugin.ROOF_THICKNESS_DIRECTION);
if (dirThick != null) {
try {
if (orthoBorder.getActionCommand().equals(dirThick))
borderGroupBtn.setSelected(orthoBorder.getModel(), true);
* chances to see it
plugin.getHomeController().getView().showError("Cannot retrieve direction: " + e.getMessage());
// Create a listener for the border buttons.
ActionListener borderActionListener = new ActionListener() {
public void actionPerformed(ActionEvent actionEvent) {
AbstractButton aButton = (AbstractButton) actionEvent.getSource();
if (aButton.isSelected())
// Register a listener for the borders buttons.
verticalBorder.addActionListener(borderActionListener);
orthoBorder.addActionListener(borderActionListener);
// Create reset button
resetButton = new JButton(new AbstractAction(resource.getString("resetButton.txt")) {
private static final long serialVersionUID = 1L;
public void actionPerformed(ActionEvent ev) {
faceAngleSlider.setValue(40);
thickModel.setLength(7.6f);
// Reset the angle for all faces to 40 deg
for (int i = 0; i < plugin.allRoofEdges.length; i++) {
plugin.allRoofEdges.setSlope(slope);
plugin.allRoofEdges.setFaceVisible(true);
// Reset the author
creator.setText(author);
// Reset the borders
borderGroupBtn.setSelected(verticalBorder.getModel(), true);
resetButton.setToolTipText(resource.getString("resetButtonInf.txt"));
// About button
aboutButton = new JButton(new AbstractAction(resource.getString("aboutButton.txt")) {
@Override
HTMLViewer viewer = new HTMLViewer();
viewer.addErrorListener(new HTMLViewer.ErrorListener() {
@Override
public void onError(Exception e) {
e.printStackTrace();
SwingUtilities.invokeLater(new Runnable() {
@Override
public void run() {
try {
viewer.setPage(GenerateRoofPlugin.class.getResource("/generateroof/resources/about.html"));
} catch (IOException e1) {
e1.printStackTrace();
try {
String lang = resource.getLocale().getLanguage();
String version = plugin.getVersion();
String url = "https://daniels118.altervista.org/sh3d/roofgenerator/about/" + "?lang=" + lang + "&ver="
+ URLEncoder.encode(version, "UTF8");
viewer.setPage(url);
} catch (IOException e) {
JScrollPane scrollPane = new JScrollPane(viewer);
JOptionPane helpPanel = new JOptionPane(scrollPane, JOptionPane.PLAIN_MESSAGE, JOptionPane.DEFAULT_OPTION);
JDialog aboutDialog = helpPanel.createDialog((JComponent) homeView, resource.getString("ROOF_GEN.title"));
aboutDialog.applyComponentOrientation(((JComponent) homeView).getComponentOrientation());
aboutDialog.setLocationByPlatform(true);
aboutDialog.setDefaultCloseOperation(JDialog.DISPOSE_ON_CLOSE);
aboutDialog.setResizable(true);
aboutDialog.setMinimumSize(new Dimension(600, 700));
aboutDialog.setVisible(true);
//aboutButton.setBackground(Color.green); //standard button, not green
aboutButton.setToolTipText(resource.getString("aboutButton_Warn.txt"));
// Column 4 Row 1
// Column 4+5 Row 9
// Column 6+7 Row 0
// Column 6+7 Row 6
// Column 4+5 Row 7
// Column 6+7 Row 7
// Column 6+7 Row 8
// Column 0 Row 9
// Column 2 Row 9
// Column 3 Row 9
// Column 4+5 Row 8
// Column 6+7 Row 9
new GridBagConstraints(6, 9, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
return roofPanel;
private class EdgesCellRenderer extends DefaultListCellRenderer {
final ImageIcon eyeCloseIcon = new ImageIcon(GenerateRoofPlugin.class.getResource("/generateroof/resources/closed-eye.png"));
final ImageIcon emptyIcon = new ImageIcon(GenerateRoofPlugin.class.getResource("/generateroof/resources/emptyIcon.png"));
@Override
public Component getListCellRendererComponent(JList<?> list, Object value, int index, boolean isSelected, boolean cellHasFocus) {
String s = value.toString();
setText(s);
boolean visible = plugin.allRoofEdges[index].isFaceVisible();
setIcon(!visible ? eyeCloseIcon : emptyIcon);
if (isSelected) {
setBackground(list.getSelectionBackground());
setForeground(list.getSelectionForeground());
} else {
setBackground(list.getBackground());
setForeground(list.getForeground());
setEnabled(list.isEnabled());
setFont(list.getFont());
setOpaque(true);
return this;
Posted by byDMA at Jun 19, 2024, 6:38:46 PM
it is a hole file GenerateRoofPluginView.java
I have changed the:
1. windows size to 800x600
2. about button
3. Edge-Panel list width -> should resize the scroll panel width
4. autor TextField -> set manually width to 250, this should resize the columns width 6-7
Posted by dorin at Jun 20, 2024, 5:15:46 PM
@1. The preview size you've propose could be good.
@2. The About button will remain GREEN for my public versions.
Some people could receive a customized version.
@3. Could be a solution but it is away too wide for other languages.
A compromise could be to replace Edges:Slope (Kanten: Neigung) text with only Edges (Kanten).
Another solution could be to replace JList with JTable or Jeks and include a header.
The invisibility checkbox could be also added for every edge to replace the eye indicator.
@4. This setting has not the expected effect.
You've modified few lines: 177, 231, 344(// Need cast int), 346,
421, 422 (//Wrong), 478.
For the above lines was enough to make proposal like in patches.
For the createUI method it's Ok to post it entirely as you've done in the paste.
I hope to not upset you. I'm not a programmer so my opinion don't count too much.
Posted by byDMA at Jun 20, 2024, 9:33:09 PM
Dorin, may be you can create a repository by sourceforge?
Posted by Puybaret at Jun 20, 2024, 11:00:58 PM
byDMA, creating a repository is probably not something that will help Dorin to rest and recover at the moment. I already asked him in the past if he could improve the layout of his plug-in to make it more compliant under macOS, something that he performed very gently.
Maybe, we shouldn’t ask him perfection and anyway, the look and feel of a user interface always depends on one’s taste.
Posted by byDMA at Jun 22, 2024, 10:43:58 AM
So, here we are. I compiled it myself and experimented with the sizes. Now it does not matter which language is used and how long or short the words are in the TittledBorder. There is no need to do tricks with the words when translating. I also tried to distribute the components and the distances evenly.
Only this is needed:
1. fix width of the edgeList
edgesList.setFixedCellWidth(200);// byDMA resize width of the List in the JScrollPane
2. corrected grids
explained: ipadx changes the width of JScrollPanel with the EdgeList.
scrollEdgesPane -> 200
faceAngleSlider -> 125
//TODO byDMA
// Column 4 Row 1
new GridBagConstraints(4, 0, 2, 7, 0, 0, GridBagConstraints.NORTH, GridBagConstraints.BOTH, new Insets(0, 0, 0, 0), 200, 0));
// Column 4+5 Row 9
new GridBagConstraints(4, 9, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(15, 0, 0, 5), 0, 0));
// Column 6+7 Row 0
new GridBagConstraints(6, 0, 2, 1, 0, 0, GridBagConstraints.NORTH, GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 15));
new GridBagConstraints(6, 1, 2, 5, 0, 1, GridBagConstraints.CENTER, GridBagConstraints.BOTH, new Insets(10, 0, 0, 0), 125, 0));
// Column 6+7 Row 6
new GridBagConstraints(6, 6, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(10, 0, 0, 0), 0, 15));
// Column 4+5 Row 7
new GridBagConstraints(4, 7, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(10, 0, 0, 0), 0, 15));
// Column 6+7 Row 7
new GridBagConstraints(6, 7, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(10, 0, 0, 0), 0, 15));
// Column 6+7 Row 8
new GridBagConstraints(6, 8, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.BOTH, new Insets(10, 0, 0, 0), 0, 0));
// Column 0 Row 9
new GridBagConstraints(0, 9, 1, 1, 1, 0, GridBagConstraints.LINE_START, GridBagConstraints.HORIZONTAL, new Insets(15, 0, 0, 0), 0, 0));
// Column 2 Row 9
new GridBagConstraints(2, 9, 1, 1, 0, 0, GridBagConstraints.LINE_END, GridBagConstraints.HORIZONTAL, new Insets(15, 0, 0, 15), 0, 0));
// Column 3 Row 9
new GridBagConstraints(3, 9, 1, 1, 0, 0, GridBagConstraints.LINE_END, GridBagConstraints.HORIZONTAL, new Insets(15, 0, 0, 15), 0, 0));
// Column 4+5 Row 8
new GridBagConstraints(4, 8, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(10, 0, 0, 0), 0, 0));
// Column 6+7 Row 9
new GridBagConstraints(6, 9, 2, 1, 0, 0, GridBagConstraints.CENTER, GridBagConstraints.HORIZONTAL, new Insets(15, 5, 0, 0), 0, 0));
return roofPanel;
