Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Weird 3D Artifacts |
| Print at Sep 28, 2026, 2:29:43 PM |
| Posted by Johannes_Angello at Sep 25, 2022, 11:46:40 AM |
Re: Weird 3D Artifacts I have the same issue with: GPU - AMD Radeon RX 6600 XT - Primär/Diskret VRAM - 8176 MB - GDDR6 2000 MHz Treiberversion - 22.20.19.11-220915a-383673E-AMD-Software-Adrenalin-Edition AMD Windows-Treiberversion - 31.0.12019.11001 Direct3D-API-Version - 12.1 Vulkan™ API Version - 1.3.217 OpenCL™ API Version - 2.0 OpenGL® API Version - 4.6 Direct3D® Driver Version - 9.14.10.01523 Vulkan™ Driver Version - 2.0.233 OpenCL® Driver Version - 31.0.12019.11001 OpenGL® Driver Version - 22.09.1462311 2D-Treiberversion - 8.1.1.1634 2D-Treiberpfad - /REGISTRY/MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0001 UI-Version - 2022.0915.1840.1936 AMD Audio-Treiberversion - 10.0.1.24 Treiberanbieter - Advanced Micro Devices, Inc. Windows Edition - Windows 10 Core (64 bit) Windows-Version - 21H2 Im trying to escalte this topic via AMD. Does anyone have got a solution yet? |
| Posted by cyphorage at Sep 25, 2022, 2:55:09 PM |
Re: Weird 3D Artifacts Just confirming that this is still an issue with latest Adrenaline driver (22.9.1) released yesterday (2022-09-21) https://www.amd.com/en/support/kb/release-notes/rn-rad-win-22-9-1 Does anyone know the exact crux of the issue so that we can report it directly to AMD? I reported this as a bug to AMD directly with their bug reporting tool. Instructions for doing so can be found here: https://www.amd.com/en/support/kb/faq/amdbrt. I have linked to this thread for further reference along with uploading some relevant screenshots. Hopefully that helps them |
| Posted by cyphorage at Sep 27, 2022, 10:24:57 PM |
Re: Weird 3D Artifacts Just confirming that this is still an issue with latest Adrenaline driver (22.9.1) released yesterday (2022-09-21) https://www.amd.com/en/support/kb/release-notes/rn-rad-win-22-9-1 Does anyone know the exact crux of the issue so that we can report it directly to AMD? I reported this as a bug to AMD directly with their bug reporting tool. Instructions for doing so can be found here: https://www.amd.com/en/support/kb/faq/amdbrt. I have linked to this thread for further reference along with uploading some relevant screenshots. Hopefully that helps them Just updated to 22.9.2 (released today, 2022-09-27) and the issue persists. I will be reporting this bug to AMD again. |
| Posted by quallemalle at Oct 21, 2022, 2:31:32 PM |
Re: Weird 3D Artifacts I recently switched my GPU from Nvidia to AMD and also can confirm this bug with 22.10.1 driver :/ Will create a bug report |
| Posted by coldcomfort at Oct 24, 2022, 4:19:44 PM |
Re: Weird 3D Artifacts Just happened to me too. I had no issues the other day and made no driver or windows update since (did install a new firewall). Only installed a few sweethome3d plugins the last time, but all worked just fine then. The 3d view window is grey now when opening the program, with no model. Then loading a model gives those artifacts above, in both the 3d view and planview (objects are all black). And everything is a mess. Tried reinstalling and got the same issues. AMD Radeon Vega 8 integrated graphics |
| Posted by Puybaret at Oct 24, 2022, 6:24:37 PM |
Re: Weird 3D Artifacts Could some of you try Sweet Home 3D executable jar with a recent version of Java 17: - download Java 17 and install it - download Sweet Home 3D executable jar - open a cmd window and run the command: java --add-opens=java.desktop/sun.awt=ALL-UNNAMED --add-opens=java.desktop/com.apple.eio=ALL-UNNAMED --add-opens=java.desktop/com.apple.eawt=ALL-UNNAMED -jar path\to\SweetHome3D-7.0.2.jarI wonder if it would run better, it could also worth to try the 32 bit version of Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by coldcomfort at Oct 25, 2022, 11:05:30 AM |
Re: Weird 3D Artifacts I fixed it by reinstalling my radeon software, with a factory reset. Downgrading to the 22.5.1 version. |
| Posted by quallemalle at Oct 28, 2022, 3:55:07 PM |
Re: Weird 3D Artifacts Tried out running the jar with Java 17 as you mentioned but it did not fix the issue :/ (AMD Driver 22.10.3) |
| Posted by GeoYla at Oct 31, 2022, 7:44:24 PM |
Re: Weird 3D Artifacts Just ran into this problem as well... so I guess we have to wait for AMD to fix it? Shame. |
| Posted by Puybaret at Oct 31, 2022, 10:38:57 PM |
Re: Weird 3D Artifacts You’re not obliged to wait for AMD good will, just downgrade to version Adrenaline 22.5.1. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 2:29:43 PM |
