Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Lean-to conservatory |
| Print at Oct 4, 2026, 11:34:09 AM |
| Posted by Weevoir at Sep 20, 2022, 1:21:39 PM |
Lean-to conservatory Has anyone done a LEAN-TO CONSERVATORY ? Full length glass walls and a sloping plastic panel roof Thanks |
| Posted by hansmex at Sep 20, 2022, 2:24:00 PM |
Re: Lean-to conservatory Did you look here? https://3dwarehouse.sketchup.com/search/?q=conservatory&searchTab=model ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Weevoir at Sep 22, 2022, 9:37:09 AM |
Re: Lean-to conservatory The one that I need is https://3dwarehouse.sketchup.com/model/e8595e...50d4d3306f1e/Conservatory and is not available in any Sweet homes compatible format Any suggestions ? |
| Posted by Weevoir at Sep 22, 2022, 9:40:44 AM |
Re: Lean-to conservatory Neither are any of the others on the same site ! |
| Posted by VeroniQ at Sep 22, 2022, 10:01:38 AM |
Re: Lean-to conservatory I could easily download and import the conservatory you mentioned in .dae... It is compatible format. |
| Posted by Keet at Sep 22, 2022, 10:44:43 AM |
Re: Lean-to conservatory A whipped together a simple example from which you can expand to the conservatory you want. All basic sweethome3d parts with only the roof "window" exported and imported to allow inclining. https://sourceforge.net/p/sweethome3d/d-models/667/ ![]() ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by VeroniQ at Sep 22, 2022, 11:42:44 AM |
Re: Lean-to conservatory Nice and useful! Thank you Keet!! |
| Posted by Weevoir at Sep 22, 2022, 3:21:38 PM |
Re: Lean-to conservatory Thank you - very useful |
| Posted by Weevoir at Sep 23, 2022, 10:41:58 AM |
Re: Lean-to conservatory The conservatory appears to be fine in the plan view - but the 3d view is different The sides are solid (no glass) and the roof is flat ! |
| Posted by VeroniQ at Sep 23, 2022, 11:39:46 AM |
Re: Lean-to conservatory Euh, not for me... What version of Sweet Home 3D do you use? |
Current timezone is GMT Oct 4, 2026, 11:34:09 AM |
