Print at Oct 4, 2026, 12:53:59 AM
Posts: 17   Pages: 2   [ Previous Page | 1 2 ]
Posted by Weevoir at Sep 24, 2022, 10:04:43 AM
Re: Lean-to conservatory
7.0.2
There is also something sticking out from the front of the conservatory
Posted by shoulders at Oct 16, 2022, 1:22:27 PM
same here, the sh3d file is basically a 4 panel glass frame.
I am using v7.0.2
Posted by ladkii at Oct 22, 2022, 12:01:14 PM
Thank you Keet!!
Posted by shoulders at Oct 22, 2022, 11:16:30 PM
I see what I did wrong, the conservatory is a SH3D which is project file and not a Furniture Library.
This file works fine.
cheer Keet
Posted by Keet at Oct 23, 2022, 7:32:19 AM
cheer Keet
The example is just a very rough and quickly put together example. I hope it gives you a starting point to create your own conservatory exactly like you want it.
Check out the posts in this forum about creating glass. It is probably a better idea to use glass objects and thin boxes for framing then resized predefined windows. You can create a window frame with boxes, put glass in it and export it as a new object. With the Shape tool you can create a triangular shape in the exact size you need and turn it into glass.
After import you can easily tilt objects for the roof part. This looks a lot better than using existing windows because the frame of existing windows will deform when you resize them. Most of a conservatory doesn't need to be a 'real' window, i.e. one that cuts a hole in a wall since you only need a low wall for the bottom part. The rest is your own framing.
Posted by shoulders at Oct 23, 2022, 7:28:09 PM
I have made a mini library under the category 'Conservatory' and I have used the principle of making the conservatory using walls. I specify the height and thickness of the conservatory wall and then snap windows, doors and glass to it from my category.
I am not the best at it but my conservatory looks ok. Using the wall method rather than free flowing everything is a lot easier and you can make a real room.
I have not got to the roof yet. :)
Posted by Keet at Oct 24, 2022, 8:09:37 AM
... and I have used the principle of making the conservatory using walls...
There's more ways to Rome so if that works for you that's great.
A little trick for your roof if you are using standard windows:
You can't tilt windows because they are made to snap into a wall. But you can export a window and import it again as a regular object. Don't check the "Door or window" checkbox when you import. That way you have a window you can tilt for your roof.
