Print at Sep 23, 2026, 5:03:37 PM
Posts: 29   Pages: 3   [ Previous Page | 1 2 3 ]
Posted by hansmex at Feb 25, 2025, 10:53:33 PM
Re: Stair builder
@Keet - excellent suggestion
@Xlance and Dorin - panels are great suggestion (please, please)
Posted by Keet at Feb 26, 2025, 6:47:07 AM
Re: Stair builder
Agree! No panels was one of the main reasons I started creating custom staircases. I never liked the thin balusters of the staircases, because I often create staircases for large, public buildings that rarely have such balusters. You will have to find a way to allow selecting the number of panels above each other and its (individual?) height. Maybe from one full panel to max 3 or 4 panels. I bet the panels will be more popular than the cylinder balusters.
Posted by Daniels118 at Feb 27, 2025, 7:41:04 PM
Re: Stair builder
@Dorin don't forget to publish your plugin on sourceforge if you want it included in the Plugin Manager!
Posted by dorin at Mar 1, 2025, 7:10:50 PM
Re: Stair builder
Of course but when the time will come.
Posted by dorin at Mar 10, 2025, 7:09:13 PM
Re: Stair builder
Probably it's time.
First stable (probably) release: Stair Builder v.1.0
and a test file .
I'll let you to discover it.
Also on Source Forge
Posted by dorin at Mar 11, 2025, 1:29:55 PM
Re: Stair builder
Errata:
While only today I've have a feedback from a macOS user you need to install this or this updated version.
I'm sorry for the inconvenience.
It have to look something like this:
@Keet & not only
On the right last row I've insert information's related to the next level(if exist).
At start, the plugin verify this and set the calculated thickness.
Modifying the steps number, the next level indicator will warn you.
When next level: 0 cm you have to be sure the last tread it is at the same elevation as upper room.
Try with the test file I've provided.
Posted by beji at Dec 3, 2025, 1:10:27 AM
Re: Stair builder
Hi Dorin
Great work on this staircase generator!
In my area, houses typically use the space under the staircase as a storage room. If you don’t mind, would you be interested in adding a new feature like the one shown in image B - something like a concrete enclosure to close off the underside of the stairs? This would make it easier for us to build a sloping wall, as shown in image C.
https://drive.google.com/file/d/1NOP7Bv8uqcxHSOYH6B1pssXvhaxr9nSy/view
By the way, thank you so much for your contribution.
Posted by dorin at Dec 4, 2025, 5:28:08 PM
Re: Stair builder
Thanks!
In general, there are three types of stairs classified according to the construction material: wood, metal, and concrete.
This is for wood, and you want something for concrete or a combination.
It is a good idea to make some adjustments for this request.
It's not simple, because it has to work for all types of shapes.
I'll try to do it, but I don't know when.
Right now, I'm working on another plugin that's putting up a lot of resistance to my one and only neuron.
Thanks again.
Posted by dorin at Dec 7, 2025, 6:12:04 PM
Re: Stair builder
@k005 About your suggestion made here .
It's a good idea!
I think will be possible in the future like is for Roof Generator.
With good and bad.
