Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: How do i build a SweetHome3D v 2.5 source project? |
| Print at Sep 30, 2026, 1:06:58 AM |
| Posted by bsyap at Aug 17, 2010, 10:42:59 AM |
Re: How do i build a SweetHome3D v 2.5 source project?Hi Puybaret, You are correct! Seems like there is no other running error after all. I can close the case. Cheers. Regards bsyap |
| Posted by Puybaret at Aug 17, 2010, 11:27:12 AM |
Re: How do i build a SweetHome3D v 2.5 source project? And why are you trying to run Sweet Home 3D from Eclipse? Any project in mind? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bsyap at Aug 18, 2010, 3:00:33 AM |
Re: How do i build a SweetHome3D v 2.5 source project? Hi Puybaret, I get to know Sweet Home 3D from Google when i typed in "free interior design software". You really doing a good job! It is a very cool interior design software. Besides that, the most exciting part is the plug-in feature provided. As all the developers do, always start reading from the README.txt before you proceed. It's good to have Eclipse as a debugging and running tool. Since i am quite new in Sweet Home 3D project(just started to compile and test the application ), maybe i will just start to be a tester and try to report some bug. I can also provide some help/answer to other users in the forum.Cheers. |
| Posted by Puybaret at Aug 18, 2010, 8:10:20 AM |
Re: How do i build a SweetHome3D v 2.5 source project? Thank you for the information and feel free to contribute! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 1:06:58 AM |
