Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: lights question |
| Print at Sep 27, 2026, 12:05:04 AM |
| Posted by pencilart at Jan 4, 2011, 4:21:39 PM |
lights question I have a question about using the lights in SH3D 3.0: When I render the scene (using the Best or next to Best setting) There is now a huge light/white spot on the ceiling. I used the Halogen light (the same light that was used for the beta tests) and have it set to 25% power. I hadn't noticed the spot on the ceiling caused by the light before. Is that a new problem? I'll have to play around with the other lights to see if that still happens. I'll attach a rendered pic to show you. ---------------------------------------- |
| Posted by Puybaret at Jan 4, 2011, 4:56:15 PM |
Re: lights question Wouldn't you have forgotten to unselect Add ceiling lights check box? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Jan 4, 2011, 6:16:27 PM |
Re: lights question That was unchecked already. I can attach a screenshot of that if you like. |
| Posted by hansmex at Jan 4, 2011, 6:22:30 PM |
Re: lights question pencilart, Indeed, lights tend to show bright white spots on ceilings, especially if the light is placed closed to the ceiling. There are a few things you can do: - place the light lower, obviously; - make the light larger, so that it seems softer; - make your ceiling (and walls) Matte so that the bright spot is not, or less, visible. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by pencilart at Jan 5, 2011, 5:52:08 PM |
Re: lights question ok, I'll try those things. Thanks! Edit: the light is now 4 feet 6 inches (I guess that means from the floor?) the ceiling was already set to matt the light is now huge, lol, but it does now look softer. ---------------------------------------- |
| Posted by Cactus at Jan 28, 2011, 1:36:02 PM |
Re: lights question Wouldn't you have forgotten to unselect Add ceiling lights check box? I have the same problem and I surely don't have unselect this check box... 'cause I didn't find it. Could you please tell me where it is? |
| Posted by hansmex at Jan 28, 2011, 2:05:49 PM |
Re: lights question Cactus, I suggest your first read the user's guide and the help files on how to work with lights. Then ask your question in such a way that you don't force us to read the entire thread to figure out what you exactly want to know. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Cactus at Feb 11, 2011, 1:04:36 PM |
Re: lights question I exactly wanted to know where is the "Add ceiling lights" check box. I finally found it, it was simply in the "create a photo" box. Thanks for your help. |
| Posted by soul at Mar 18, 2011, 10:39:07 PM |
Re: lights question hi ppl, this software is awesome, i really thank and send appreciates to developers, after 2 full days working on user guide and samples i could succesfully create a room scene, i tried lots but just couldnt make sum so i m asking to masters, one of walls just dont change the color, other one (on right) is close to white but the one which is trouble(one left) just dont change color, i tried to add texture by a white wallpaper but it just didnt take the effect again, its always grey, isnt there a way to get together all walls or selected ones to behave together like elevating and CHANGİNG COLOR , wall just dont change the color, may u help,also the frame and curtain have white pixels around, i just couldnt solve that problem after many tries by lights, do u have any advice for that too?? i m making arrangements with ceiling lights!! may u tell me what basicly ceiling lights add? cus in the sample pic below ceiling lights added and one more white are next of white spot(at top of pic,and i know its cus of in the air-area light that pencilart used in his scene),i dunno where it came from.. here is my sample http://i11.photobucket.com/albums/a178/mcdost/aa.png |
| Posted by Puybaret at Mar 19, 2011, 12:39:19 PM |
Re: lights question Are you sure you changed the right side of the wall? Do you the color or texture change in the 3D view ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 12:05:04 AM |
