Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Cut out |
| Print at Oct 4, 2026, 12:48:32 PM |
| Posted by Mike53 at Nov 4, 2018, 5:19:43 PM |
Re: Cut out You may need to disable magnetism while positioning them. Mike |
| Posted by stef.salmon at Nov 4, 2018, 5:25:15 PM |
Re: Cut out Hi Mike, If I disable magnetism I can line up the door, but it doesn't cutout the invisible box like it does on a normal wall. |
| Posted by Puybaret at Nov 4, 2018, 5:33:27 PM |
Re: Cut out Invisible boxes don't cut other pieces of furniture. They only cut walls and floors as show in this tip. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stef.salmon at Nov 4, 2018, 5:47:08 PM |
Re: Cut out Is there a way of having a transparent wall with a door? I have managed to put in some transparent glass walls, but now I just need to add a door which actually has a cutout. https://www.dropbox.com/s/ec2gvrl4mr89688/KWS_SS.png?dl=0 |
| Posted by Mike53 at Nov 4, 2018, 6:11:28 PM |
Re: Cut out Not sure i understand correctly, but have you thought to insert the door into a wall with its opacity set to nearly clear, then exporting both the door and the wall? |
| Posted by stef.salmon at Nov 4, 2018, 6:49:01 PM |
Re: Cut out Never tried to create an object before! That worked a treat...thanks Mike ![]() |
| Posted by Mike53 at Nov 4, 2018, 6:55:15 PM |
Re: Cut out Thank the lord its nearly january, i only get 1 good idea a year. Mike |
Current timezone is GMT Oct 4, 2026, 12:48:32 PM |
