Print at Oct 14, 2026, 1:51:00 PM
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Posted by chicosRV at Feb 21, 2013, 10:08:24 PM
I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception
Posted by Puybaret at Feb 21, 2013, 11:11:56 PM
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception
How did you create the jar file? What exception did you get?
Posted by chicosRV at Feb 22, 2013, 4:23:51 PM
I export the proyect as a JAR file with all the files and resources, and put the name of the main class. The proyect is exported but when I try to execute it, it simple says Java Exception
Posted by Puybaret at Feb 22, 2013, 7:05:15 PM
As the project needs some DLLs, it can't work the way you did.
You should generate a Jar file with the JarExecutable target of the Ant file provided with the project.
Posted by chicosRV at Feb 26, 2013, 6:46:01 PM
sorry but could you write me a step by step of how i could do this, i have never done this before
Posted by Puybaret at Feb 26, 2013, 6:50:13 PM
Do you use Eclipse?
Posted by chicosRV at Feb 26, 2013, 7:37:58 PM
yes
Posted by Puybaret at Feb 26, 2013, 8:12:36 PM
- Select build.xml
- In its contextual menu, choose Run as > Ant Build...
- Select the target named JarExecutable
- Click Run
- Once finished, you'll find the Jar executable file in the install subdirectory (refresh its content with F5 if necessary)
Posted by chicosRV at Feb 26, 2013, 8:36:25 PM
it give the next error
Buildfile: D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build.xml
build:
[mkdir] Created dir: D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build\classes
[javac] Compiling 2 source files to D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build\classes
BUILD FAILED
D:\Sylenia\Grupo RV\Workspace\SweetHome3D-3.7-src\build.xml:43: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre7"
Posted by Puybaret at Feb 26, 2013, 8:45:58 PM
Select a JDK instead of a JRE in the JRE tab of Ant configuration.
Don't forget that Google could help you too....
