Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception |
| Print at Oct 13, 2026, 7:13:32 AM |
| Posted by angeliclayer at Feb 23, 2015, 8:26:30 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception Hi, Does anyone have definitive steps for this? I'm experiencing the build fail issue same as chicosRV. If I follow the steps above, I do not see an option to select the JDK instead of JRE. I'm using Eclipse version 4.2 and Eclipse Java Development Tools 3.8.2. Thanks in advance for any advice on this matter. |
| Posted by Puybaret at Feb 24, 2015, 10:20:57 AM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception In the JRE tab of Ant configuration, click on Install JREs and add a JVM which root directory matches a JDK installed on your computer. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by angeliclayer at Feb 24, 2015, 6:28:35 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception Thank you so much! I have solved it now. It was for a very final year project so I'm very thankful for the fast response. :) |
| Posted by Puybaret at Feb 26, 2015, 5:42:40 PM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception Great you could make it. ![]() Would it be possible that you share with the community what your project was about? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by angeliclayer at Mar 8, 2015, 12:31:16 AM |
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception Sure! I'm doing my dissertation about this software to help Occupational Therapy patients during the pre-discharge home visit assessment. I'm currently just improving on someone else's plugin but also needed to improve on some of the UI to allow for people who aren't very dexterous to be able to use the software. I have also tried adding the to the furniture catalogue a few occupational therapy items by default. I'm currently unable to share this at the moment because the plug-in (other than the changes I've made) isn't mine but I'll gladly share what I've coded myself (after I've submitted my work) :D |
Current timezone is GMT Oct 13, 2026, 7:13:32 AM |
