Print at Sep 30, 2026, 1:07:35 AM
Posts: 17   Pages: 2   [ Previous Page | 1 2 ]
Posted by mnadeem at Apr 21, 2013, 1:27:19 AM
Re: text on walls
Hi lately very busy . i still can not write text on wall . or i think i am not giving more information what i am trying to say, so i have a wall create in sh3d then give some colors , some people hanged there image or pictures , but simply want to write on it .then want to copy as a new furniture then export to obj format , so then i can use it many time as i wish , i hope not asking too much
Posted by Puybaret at Apr 21, 2013, 12:25:37 PM
Re: text on walls
There's no direct way to write a text on the wall. As Hans partly suggested, a workaround is to create an image containing that text (eventually with a transparent background), import that image in the program as a texture, and apply that texture on a thin box.
Of course, if you have to do that many times, it will become tedious and Sweet Home 3D might not be the right solution for you.
Posted by mnadeem at Apr 21, 2013, 12:33:55 PM
Re: text on walls
So back again . ?: If i have a pic or jpg or any type format how can i add to my furniture or as a object 3d still not understanding how this program works , in furniture import wizard only you can chose between obj,dae 3ds,lws,zip. but no jpg file , is there any one tell me what should i do thanks in regards
Posted by mnadeem at Apr 21, 2013, 12:43:14 PM
Re: text on walls
Ok if so
then tell me how can i add frame made by any picture or photo as , or my photo taken by camera to hanged in living room or bedroom
Posted by mnadeem at Apr 21, 2013, 12:50:12 PM
Re: text on walls
HI there must be a way to add 2D models import like 3D models import
Posted by Puybaret at Apr 21, 2013, 1:00:38 PM
Re: text on walls
As said previously, import the image containing your text in the program as a texture, and apply that texture on a thin box (found in Miscellaneous category).
Posted by mnadeem at Apr 21, 2013, 2:05:03 PM
Re: text on walls
hi as you say ,import the image containing your text in the program as a texture, and apply that texture on a thin box,, how is there any pdf file to understand , i have import jpg file but not found any where , its vanished
