Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Slope lot front to back |
| Print at Sep 2, 2026, 1:23:42 AM |
| Posted by okh at Mar 25, 2014, 11:15:56 AM |
Re: Slope lot front to back ..please send me the example of boxes and triangles. Might as well upload as a Sourceforge ticket (299). Example files to give an illustration of usage: - template_scandinavian.sh3d - geo_sample.sh3d This is pretty basic geometry (no copyright on triangles and boxes) and some stretching and resizing will be necessary to achieve the desired effect - and normally the use of several SH3D levels. So far these models have covered most of needs so far, but please let me know if other elements could be of use. ok |
| Posted by macfrog at Mar 30, 2014, 10:05:16 PM |
Re: Slope lot front to back Hello, maybe this illustration will help. It's been a similar problem, ot quite exactly what you might need but i think you'll get the idea: look from here greets |
| Posted by maxmaia at Aug 19, 2014, 10:29:59 AM |
Re: Slope lot front to back On this forum I could find excelent ideas and I'd like to thank you for all contributions. I have in mind one type of slope ground, which graphically can be represented as: .1m --------------- 2m ..\.................| ...\................| ....\...............| ... 0m -------------1m Hopefully my drawing will be displayed correctly. I put on the corners also the heights of slope (eg. 1m = 1 meter). Can you please tell me if this slope ground can be made using triangles, and if yes, I'd appreciate your advices and help. Thanks. |
| Posted by okh at Aug 19, 2014, 2:35:33 PM |
Re: Slope lot front to back Yes, it can. But you may have to combine several triangles and boxes. Especially if you have a basement (a level below ground) it may take some work and clever use of triangles. ok |
| Posted by maxmaia at Aug 19, 2014, 3:33:56 PM |
Re: Slope lot front to back Yes, it can. But you may have to combine several triangles and boxes. Especially if you have a basement (a level below ground) it may take some work and clever use of triangles. ok Thanks for feedback. If is possible please describe in couple of steps what needs to be done. I've tried to build tringle objects, but with no luck as the ground elevation is different in each tringle point. Many thanks. |
| Posted by okh at Aug 19, 2014, 6:27:19 PM |
Re: Slope lot front to back A couple of steps is perhaps optimistic - Will you have a basement? (If so you need the exact outline and placement of the building) - What are the dimensions of the sides? - What is the height of the middle? You can do a lot with the triangles found in the Sourceforge ticket (299), mentioned above. But maybe not all. The Scandinavian template is probably closest. If you send me an e-mail that I can reply to with attachment, I can have look (please, include dimensions of terrain and maybe house outline). ok |
| Posted by maxmaia at Aug 20, 2014, 8:20:21 AM |
Re: Slope lot front to back Thanks, I sent you a mail with the ground format I'm looking for. |
| Posted by okh at Aug 20, 2014, 9:26:52 AM |
Re: Slope lot front to back Looked at it and sent you a possible solution: adding a surface (model). Hope that works. Good luck. ok |
| Posted by okh at Aug 20, 2014, 10:10:16 AM |
Re: Slope lot front to back 1m --------------- 2m ..\.................| ...\................| ....\...............| ... 0m -------------1m Actually, there is a way of creating such terrain with SH3D.
This will work for relatively simple terrains, but has the disadvantage of being a permanent surface that does not cut automatically (so it will be visible in a basement). Also, be careful not to make the "room" too complicated as SH3D will reach a point where the ceilings cannot be calculated accurately - and then it will not work. But, of course, you can make several elements and join them if you are patient. But if the terrain is complicated, it is probably easier to use a 3D modeling software. ok |
| Posted by maxmaia at Aug 20, 2014, 10:31:34 AM |
Re: Slope lot front to back Excellent. Great work with simple steps! Thanks again! |
Current timezone is GMT Sep 2, 2026, 1:23:42 AM |
