Print at Oct 2, 2026, 12:09:52 AM
Posts: 25   Pages: 3   [ Previous Page | 1 2 3 | Next Page ]
Posted by Dares at Apr 22, 2014, 12:40:40 PM
Re: How to install SweetHome 3d on website
Yes ok, but where i cant find SweetHome3DApplet.jar ?
Posted by Dares at Apr 25, 2014, 12:37:25 PM
Ok I solve my problem. Thanks any help
Posted by susonne at May 22, 2014, 10:43:18 AM
Hallo,
I would also like to install SH3D online, I installed the Viewer sucessfully.
I don't really understand which source codes I need to compare. Where is the source code of the online version?
Sorry if my question was unqualified...I really tried to figure out!
I work with java and eclipse, but I am still a beginner I guess.
Greetings
Susanne
Posted by Puybaret at May 22, 2014, 11:56:12 AM
The source code of Sweet Home 3D, the online version and the viewer are in the same project available here.
To build the jar files of the online version, select the file build.xml and choose Run > External Tools > External Tools Configuration… menu item in Eclipse. In the dialog that opens, select the target named applet in the Targets tab, and select a JDK (not a JRE) in the JRE tab, then click on Run.
As explained in README.TXT file, note that you'll need first to create or retrieve a keys.keytool file to sign the applet jars (this keystore file will have to be named keys.p12 in the coming version).
Posted by susonne at May 22, 2014, 6:37:31 PM
Thank you for the detailed answer!!! I will try as soon as possible!!!
And anyways thanks for this really cool application!!!
Posted by susonne at May 30, 2014, 10:49:07 PM
Great! It works! Thank you again!
I have one extra question, is it somehow possible to add an extra plug-in to this online version?
I want to demonstrate a really small plug-in for an exam next week.
Posted by Puybaret at Jun 1, 2014, 9:42:04 PM
Yes, but I didn't try it for a while.
See pluginURLs in SweetHome3DApplet javadoc.
As there's no menu in the applet, keep in mind that you should set plug-in small icon to get an access to it in the tool bar.
Posted by Just_MAX at Aug 25, 2014, 2:10:01 PM
Hi!
Compiled and signed files,
After uploading files on site i got error:
JNLPSigningException
Failed to validate signing of launch file. The signed version does not match the downloaded version.
Any idea how to fix it?
Posted by Just_MAX at Sep 10, 2014, 4:40:26 AM
Compiled older version 4.3 and it works fine
Posted by Puybaret at Sep 11, 2014, 5:24:50 PM
For security reasons, Oracle now recommends (and might obliges one day) to include the APPLICATION.JNLP file of the applet in its main jar. That's the main change I performed in Sweet Home 3D applet version 4.4 (see diff with version 4.3 here).
So, if you want to change the libraries you need in your version of the applet, you'll have to update the file SweetHome3DApplet.jnlp found in deploy subfolder, then update jnlp_embedded parameter and jars variable in SweetHome3DApplet.html.
