Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Making continues walls |
| Print at Oct 2, 2026, 1:27:00 AM |
| Posted by Lumaja at Jul 30, 2014, 3:35:54 PM |
Making continues walls Making continues walls. Wall thickness .10 No.1 – Enter 2.040 and is correct 1.940 No.2 – Enter .800 is correct at .700 No.3 – Enter .410 is wrong should be .310 No.4 – Enter 1.630 is wrong should be 1.530 ( after enter No.3 the wall turns up I have to turn down or enter angle 0 degrees). No.5 – Enter .845 is wrong should be .745 No.6 – Enter .700 is wrong should be .610 what am i doing wrong? |
| Posted by hansmex at Jul 30, 2014, 3:53:28 PM |
Re: Making continues walls It's difficult to help you without your sh3d file. Look here to see how you can share it. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Lumaja at Jul 31, 2014, 7:34:03 AM |
Re: Making continues walls More Help How to get picture of the plan 2D I only get 3D picture |
| Posted by okh at Jul 31, 2014, 9:54:54 AM |
Re: Making continues walls Depends what you mean. Adjust window you want to correct size.
ok |
| Posted by Lumaja at Jul 31, 2014, 1:50:04 PM |
Re: Making continues walls Thank you for you help My idea was to send to you a picture of my 2D plan as your ask before, taking the print screen is a picture of all the screen include SH, is this the way you want? |
| Posted by okh at Jul 31, 2014, 2:05:59 PM |
Re: Making continues walls Hi again, I have still not quite understood your problem in the first post, therefore maybe the plan and/or a screenshot could help explain as Hansmex suggests. ok |
| Posted by Lumaja at Aug 1, 2014, 7:39:21 AM |
Re: Making continues walls Thank you all your people for the help. I still don’t understand how to share a picture or share a file, my picture is in Ubuntu Home folder with name TRY 66 I tried but it dint come like your explained. I don’t want annoying your people with this and I carry on making one wall at a time. Once again Thank you. |
| Posted by dorin at Aug 1, 2014, 12:06:18 PM |
Re: Making continues walls About your problem with drawing walls, read again this: http://www.sweethome3d.com/userGuide.jsp#drawingWalls For the connected walls install AdvanceEditing plugin. For share or insert a picture follow this: http://www.sweethome3d.com/support/forum/viewthread_thread,1886 You can't upload something directly from your computer but via mediafire. Dorin ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Lumaja at Aug 14, 2014, 6:27:24 AM |
Re: Making continues walls Hoping this is correct. http://file:///home/luis/TRY66.png |
| Posted by dorin at Aug 16, 2014, 5:17:55 PM |
Re: Making continues walls NO, is not correct! You CAN'T use your local file. You must create an account on madiafire.com (for egsample), upload your files ther and then share it according to this tutorial. Dorin PS The tutorial is a little bit outdated but after few attempt you will win. Good luck! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 2, 2026, 1:27:00 AM |
