Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Tiny display in Win 8.1 |
| Print at Oct 3, 2026, 9:56:42 PM |
| Posted by adlerhn at Jul 7, 2016, 1:22:45 AM |
Re: Tiny display in Win 8.1-Dcom.eteks.sweethome3d.resolutionScale=2.5That works beautifully! I had set -Dcom.eteks.sweethome3d.resolutionScale=2, but some fonts were huge. I have now set the other parameters as suggested (keeping resolutionScale=2 though), and everything looks great. |
| Posted by hds at Jul 11, 2016, 4:41:28 PM |
Re: Tiny display in Win 8.1 Is there a solution for the online version? I have a 4K lapop screen... |
| Posted by mtm216 at Sep 11, 2016, 12:38:25 AM |
Re: Tiny display in Win 8.1 Just to say that on Windows 10 on a Surface book I had the same issue, but this .ini file fix worked perfectly - Thanks |
| Posted by Gavinx at Dec 10, 2016, 1:40:43 PM |
Re: Tiny display in Win 8.1 I am running a Lenovo Yoga and am having the problems mentioned above. After applying the SweetHome3D.l4j.ini fix I got some relief. Everything displays correctly except for the list of furniture items used in the plan - which is displayed as a list in the lower left panel of the screen. This list is scrunched up. Is there a fix for this? Thanks |
| Posted by Miker777 at Jan 8, 2017, 5:23:10 PM |
Re: Tiny display in Win 8.1 Hi. I made this change to sh3d and must say the text size is much better for me, but, if i open - close - reopen a separate function, eg, photo or create shape, each time i open it the text size enlarges until it becomes unusuable, any idea why this would be. Thanks Mike |
| Posted by Miker777 at Jan 8, 2017, 5:46:58 PM |
Re: Tiny display in Win 8.1 Images might explain it better. Normal ![]() ![]() |
| Posted by rajeshdave at Jan 12, 2017, 10:02:16 AM |
Re: Tiny display in Win 8.1 Hi, Solve the Problem thanks a lot is there any way to make the tools icons look bigger Thank you |
| Posted by Puybaret at Jan 18, 2017, 12:12:08 PM |
Re: Tiny display in Win 8.1 Mike, I found the bug you reported. It will be fixed in the next version. Thanks for reporting it ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Miker777 at Jan 18, 2017, 6:17:53 PM |
Re: Tiny display in Win 8.1 Your the man Sorry i keep finding them ![]() |
| Posted by Puybaret at Jan 18, 2017, 7:11:23 PM |
Re: Tiny display in Win 8.1 Sorry i keep finding them As long as you report them (gently), it's not a problem! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 9:56:42 PM |
