Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Need to deploy on Tomcat serer |
| Print at Sep 1, 2026, 9:00:15 AM |
| Posted by prabath at Dec 24, 2014, 6:33:15 AM |
Need to deploy on Tomcat serer Hi I want to deploy sweethome3d jar on a server. Please tell me how to do that |
| Posted by Puybaret at Dec 25, 2014, 7:57:32 PM |
Re: Need to deploy on Tomcat serer What do you mean by deploying sweethome3d jar on a server? You want to try to deploy the online version on a web server? If it's the case, the source code and the search engine of the forum will give you many hints. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by prabath at Dec 29, 2014, 6:17:38 AM |
Re: Need to deploy on Tomcat serer Thank you for your reply. yes of Course. I want to deploy the online version and want to access through a browser. (like - http://www.sweethome3d.com/SweetHome3DOnline.jsp). Please help me to deploy this. Thank you |
| Posted by prabath at Dec 29, 2014, 11:42:10 AM |
Re: Need to deploy on Tomcat serer Thanks for your Hint. I was able to set it up. When I set it up as a desktop application, application doen't allow me to save the designed floor plan. It says "Can't check if home exists". Please help me. |
| Posted by prabath at Dec 30, 2014, 11:26:10 AM |
Re: Need to deploy on Tomcat serer Appreciate your reply... |
| Posted by Puybaret at Dec 30, 2014, 2:59:24 PM |
Re: Need to deploy on Tomcat serer Look at the javadoc and how it's deployed on sweethome3d.com. The following threads might help you too: http://www.sweethome3d.com/support/forum/viewthread_thread,1113 http://www.sweethome3d.com/support/forum/viewthread_thread,1454 http://www.sweethome3d.com/support/forum/viewthread_thread,1435 http://www.sweethome3d.com/support/forum/viewthread_thread,2608 There's no other documentation about this subject, but feel free to write one if you want. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by prabath at Jan 9, 2015, 8:24:13 AM |
Re: Need to deploy on Tomcat serer Thanks Putybert. |
| Posted by prabath at Jan 9, 2015, 10:07:20 AM |
Re: Need to deploy on Tomcat serer Hi Mr Puybaret I want to load the Floor Plan directly. All Parameters should be set internally. Please tell me how to do it. Thank YOu |
| Posted by prabath at Jan 12, 2015, 12:12:29 PM |
| Posted by Puybaret at Jan 12, 2015, 1:30:16 PM |
Re: Need to deploy on Tomcat serer You should set the floor plan you want in the applet parameter named defaultHome. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 1, 2026, 9:00:15 AM |
