Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Need to deploy on Tomcat serer |
| Print at Sep 1, 2026, 8:57:28 AM |
| Posted by okh at Jan 30, 2015, 7:34:27 AM |
Re: Need to deploy on Tomcat serer .. online System for the Electricians to design Lights, Sockets and A/C systems for a selected Floor Plan. The application reads the PDF files and can detect the Floor Plans. Sounds interesting. You have probably noticed that the question of electric symbols appear from time to time: e.g. 5531: 2D Symbols and the 5416: Schneider project. If your work results in something of interest, it would be great if you would post something about it. And good luck. ok |
| Posted by prabath at Feb 2, 2015, 3:40:43 AM |
Re: Need to deploy on Tomcat serer Ys of Course. I'm really interesting. I'll look in to that |
| Posted by prabath at Feb 2, 2015, 10:49:19 AM |
Re: Need to deploy on Tomcat serer Hi Puybaret Can you pls help to add a button as requested above? |
| Posted by Puybaret at Feb 2, 2015, 2:44:27 PM |
Re: Need to deploy on Tomcat serer Thanks for giving details about your goals. ![]() If you want to add a button to the applet toolbar, you should override createHomeController method in the subclass of AppletApplication you started before. Once you retrieved super implementation, inspire yourself of the (not so cleaned) existing implementation to retrieve the toolbar and add a button to it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by prabath at Feb 3, 2015, 6:12:51 AM |
Re: Need to deploy on Tomcat serer Thank You Puybaret..... |
| Posted by prabath at Feb 3, 2015, 5:48:03 PM |
Re: Need to deploy on Tomcat serer Hi Pyubaret I enhanced my application to detect the lines of the Floor plan which is in the grid. I used Boof CV(http://boofcv.org/index.php?title=Main_Page) libraries to do that. For the moment, it doesn't support all the floor plans. I'm improving the my line detecting algorithm. But when I deployed the application on server(as a web application) with new feature, it says BoofCV libraries can't be found. I added BoofCV libraries under "otherLibraries" Tag in build.xml file. It compiles perfectly, but when it runs as a web application , it can't load added Boof CV libs. I would be thankful , if you tell me if there is another way to add libraries. Thank You.. |
| Posted by prabath at Feb 4, 2015, 5:32:35 PM |
Re: Need to deploy on Tomcat serer Hi Pyubaret ... I think you will help me on this. I'm bit stuck on this Thank You |
| Posted by Puybaret at Feb 4, 2015, 7:07:30 PM |
Re: Need to deploy on Tomcat serer Manage the new library as the other ones of Sweet Home 3D. Llook how batik-svgpathparser-1.7.jar is handled for example, and keep in mind that in applets environment you'll have to update JNLP file as well as applet HTML code. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by prabath at Feb 5, 2015, 3:16:34 AM |
Re: Need to deploy on Tomcat serer Thank..... You Puybaret ......., It's working |
| Posted by prabath at Feb 5, 2015, 9:54:53 AM |
Re: Need to deploy on Tomcat serer Hi Puybaret.... If you allow me , I would like to answer the questions which are publish in this forum and help the others.. Please let me know your decision.... |
Current timezone is GMT Sep 1, 2026, 8:57:28 AM |
