Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Shape Generator plug-in |
| Print at Aug 9, 2026, 12:42:36 PM |
| Posted by Puybaret at Nov 21, 2020, 9:53:28 AM |
Re: Shape Generator plug-in Here's the version 1.2 of ShapeGenerator plug-in which provides an additional view of the 3D model from entered coordinates, when you select the new 3D preview radio button. ![]() Many thanks to Dorin who programmed this change! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by VeroniQ at Nov 21, 2020, 12:54:40 PM |
Re: Shape Generator plug-in Ah! Good news, very useful. Thanks both of you. |
| Posted by dorin at Nov 21, 2020, 7:17:50 PM |
Re: Shape Generator plug-in I want to show some tips: 1. Triangular prism Some explanation: -On Shape Generator set to pair of points at same coordinate. In this case I chose 5+8 and 6+7. -In plan, select the generated shape and open Modify furniture - modify materials. - As You see in second image there are 5 sides in place of 6 2. Pyramid -Same procedure but for 4 upper points. 3. Roof part -Make more and combine in plan. -I recommend to apply texture AFTER resize the shape (if you need to resize) And this could be this sample ![]() Hope to be useful to somebody. PS. Don't believe Emmanuel entirely; He write all codes, I have only the idea and garbage of useless file. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by hansmex at Nov 21, 2020, 7:48:02 PM |
Re: Shape Generator plug-in Thanks for the examples. Finally I may give it a try myself 😜 H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by VeroniQ at Nov 21, 2020, 9:34:31 PM |
Re: Shape Generator plug-in So do I. |
| Posted by Hampi at Sep 10, 2021, 8:51:54 AM |
Re: Shape Generator plug-in Very nice plug-in. I would love when I could save some coordinates for future use. Because it takes time to put in the coordinates correct for different shapes, it would be nice if I can save already created coordinate with a name, an later on restore that coordinates. Then I only have to make small adjustments to this example. Similar to the "Reset coordinates", only that I can choose reset to which shape: |
| Posted by zuo at Sep 12, 2021, 9:10:11 AM |
Re: Shape Generator plug-in Hello, I want to fork this plugin in order to create two ones:
That cannot be done with that tool because they can need more point and also It can be done with more specific parameter to be more user friendly. I think that this can be done easily starting from this plugin and creating small customization, but I do not find the source code, is it available? |
| Posted by Puybaret at Sep 15, 2021, 10:54:32 PM |
Re: Shape Generator plug-in Thanks for proposing to create new plug-ins. The source code of this plug-in included in the SH3P file (which is just a zipped file). For your information, Dorin already created the Multiplier plug-in which can be used to create stairs and he also started to work on a Roof plug-in. Maybe you can help him? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 9, 2026, 12:42:36 PM |
