Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Fatal error at starting : need to updated drivers opengl directX |
| Print at Oct 5, 2026, 5:16:49 AM |
| Posted by wannerb21 at Mar 27, 2017, 3:44:46 AM |
Re: Fatal error at starting : need to updated drivers opengl directXI downloaded the program on a windows 7 ultimate (TRAVELING so use the old trusty laptop) Worked fine and allowed me to save the 3D pictures and even allowed me to edit the 3D pics in the initial session. When I went to reopen them for a second session the fatal error message closed the program down. I downloaded the drivers, but no luck. Seems strange that it all worked perfectly when the program was first installed. |
| Posted by bdfd at Mar 28, 2017, 6:04:48 AM |
Re: Fatal error at starting : need to updated drivers opengl directX Hi, Can you verify the version of java ? ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by [email protected] at Aug 9, 2017, 9:09:34 AM |
Re: Fatal error at starting : need to updated drivers opengl directX Is there any solution of this drivers problem??? |
| Posted by Puybaret at Aug 10, 2017, 3:58:08 PM |
Re: Fatal error at starting : need to updated drivers opengl directX Sorry but I fear there will be never a universal solution for drivers. Sometimes, a system update breaks something, sometimes a driver update breaks something else. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Nitemare at Aug 16, 2017, 11:08:08 AM |
Re: Fatal error at starting : need to updated drivers opengl directX This is an old problem: http://www.sweethome3d.com/support/forum/viewthread_thread,6206 |
| Posted by pooky2483 at Dec 11, 2019, 6:05:10 PM |
Re: Fatal error at starting : need to updated drivers opengl directX Well, as of 11 Dec 2019 the problem still exists. I'm running Kubuntu16.04LTS OpenGL Version 3.0 Mesa 18.0.5 ---------------------------------------- ![]() ![]() |
| Posted by phpworm at Mar 6, 2020, 12:38:18 PM |
Re: Fatal error at starting : need to updated drivers opengl directX I'm having the same issue as of 3 March 2020 Linux Mint 17 OpenGL version 4.5.0 NVIDIA 384.130 I can run the older version available through the package manager without any problems, but the downloaded current version tells me to update my drivers even though I'm using the recommended drivers. Is there no solution for this? |
| Posted by phpworm at Mar 6, 2020, 2:04:02 PM |
Re: Fatal error at starting : need to updated drivers opengl directX UPDATE: I feel pretty stupid but after running the file named "SweetHome3D-Java3D-1_5_2" instead of "SweetHome3D" it is working, and appears to be the current version. It was just the filename throwing me off. |
| Posted by mmanzur at Apr 8, 2020, 2:12:46 AM |
Re: Fatal error at starting : need to updated drivers opengl directXHave the same problem in 64 bits version. I install the 32 bit versions and the problem has gone ![]() |
Current timezone is GMT Oct 5, 2026, 5:16:49 AM |
