Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to create a down light embedded in the ceiling |
| Print at Sep 23, 2026, 11:56:35 PM |
| Posted by okh at May 4, 2018, 10:38:18 AM |
Re: How to create a down light embedded in the ceiling A suggestion from Антон to use neutral lightsource insted of the above Incandescent, same models, but lightsource colour changed from #BB9854 to #EEEEEE. SF 3D models 400 updated with new 'neutral light' file: spot_light_cutout_dir_eeeeee_neutral.sh3d There are many elements to lightsources and renderings. Key to get a better result is studying posts by Ceciliabr and enkonyito on multiple lightsources and advanced rendering. Just for reference, image below lists some of the predefined lightsource colour settings (to compare with the built in lightsources). ok |
| Posted by enkonyito at May 6, 2018, 12:12:26 AM |
Re: How to create a down light embedded in the ceiling okh, in relation to your interrogation, Last attempt of the day, a directional downlight with here are some details.<light catalogId='okh#spot_dir_cut' name='Spot_focus_dir' creator='okh' model='1/downlight_directional.obj' icon='0' x='69.5' y='290.55923' width='20.0' depth='10.0' height='10.0' modelSize='14936' staircaseCutOutShape='m .52,0.5 a .23,.46 0,0,1 .46,0 a .23,.46 0,0,1 -.46,0 z' power='0.4'>By default, SH3D uses the SphereLight type to render lights with the Sunflow rendering engine. As you already know, just add these properties for an object to be considered a light by SH3D. The LIGHT_SOURCE_DIAMETER property is optional. If it is not present, a default value is used for the calculation of the radius of the sphere as for the lights created before SH3D-3.0. When it is present, its value is taken into account and makes it possible to obtain soft shadows when the size of the light is enlarged. Regarding the position of the light source in the Home.xml file, the values represent a percentage of the width-depth-height of the object containing it. In your example, <lightSource x='0.25' y='0.5' z='0.7' color='00BB9854' diameter='0.125'/>lightSourceX#n=0.25*lightWidthMy trick to properly position the light sources of a light is to match the lower left corner of the object with the origin (0, 0) of the Sweet Home 3D plan knowing that the Y axis is reversed. modelXplan = modelWidth / 2modelElevationProperties = modelElevationPlanHoping to have been pretty clear. ---------------------------------------- EnkoNyito |
| Posted by rontant at Jul 13, 2018, 2:44:19 AM |
Re: How to create a down light embedded in the ceiling This is a very informative thread that got buried deep and maybe it should be made sticky. Now, if I observe correctly, basically a false ceiling is proposed to accomodate the embedded ceiling light without creating a hole on the floor on upper level. I see there's one issue though on certain house design. A gap between the false ceiling and the upper level floor can be exposed. Please look at my rendered photos below: Look at the LEFT side of the photo. How do you guys put an embedded light on the ceiling on the first level without getting the gap (of the false ceiling) exposed? ![]() Same, if we are to put a false ceiling above the painting, wouldn't the gap be exposed? |
| Posted by Ceciliabr at Jul 13, 2018, 11:15:12 AM |
Re: How to create a down light embedded in the ceiling Same, if we are to put a false ceiling above the painting, wouldn't the gap be exposed? Sure, but it's easy to just insert a box to cover the gap.Or you can have a look at this post . Half way down, starting with: And – while I'm at it: you will find a fix to mask the more complex cut-outs, like from a spiral staircase. Cec EDIT: How hard can it be for me to get a link working today... |
| Posted by rontant at Jul 14, 2018, 12:41:13 AM |
Re: How to create a down light embedded in the ceiling Thanks Ceciliabr. I'll study it. |
| Posted by r921vs at Aug 19, 2018, 6:42:11 AM |
Re: How to create a down light embedded in the ceiling New light sources give excellent opportunities! Thank you, okh! |
| Posted by knxville at Oct 29, 2018, 7:51:55 AM |
Re: How to create a down light embedded in the ceiling New light sources give excellent opportunities! Thank you, okh!How on earth did you light this? It's so even. I can't for the life of me get even lighting on all my walls and ceiling. |
Current timezone is GMT Sep 23, 2026, 11:56:35 PM |
