Print at Sep 30, 2026, 6:57:03 AM
Posts: 41   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Posted by Golia at Jul 28, 2018, 5:16:06 PM
Re: Doesn't launch anymore in Ubuntu 17.10
it only happens to me that it does not work FurnitureLibraryEditor?
Posted by UbuntuBirdy at Jul 28, 2018, 6:13:20 PM
Not only to you. I can start it and I can load a library, but I'm not able to do something else... If I execute any of the other functions nothing will happen.
Posted by UbuntuBirdy at Feb 12, 2019, 10:26:50 AM
Since last week an extensive update for OpenGL was released, I can start SH3D again with the standard script (SweetHome3D; SweetHome3D-Java3D-1_5_2 is not longer needed), so Java3D runs on Ubuntu now also in version 1.6.
Posted by hansmex at Feb 12, 2019, 11:43:55 AM
Congratulations UB!
I'm jealous you can use SH3D out of the box. On my system nothing happens :-(
Posted by UbuntuBirdy at Feb 12, 2019, 12:04:44 PM
Hans, try the follwoing command in your terminal:
glxinfo | grep 'version'
Which version of OpenGL does this indicate?
Posted by hansmex at Feb 12, 2019, 1:03:03 PM
And the answer is....
server glx version string: 1.4
client glx version string: 1.4
GLX version: 1.4
OpenGL core profile version string: 4.6.0 NVIDIA 390.77
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL version string: 4.6.0 NVIDIA 390.77
OpenGL shading language version string: 4.60 NVIDIA
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 390.77
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
Problem is: SH3D doesn't do anything at all with either script.
Posted by UbuntuBirdy at Feb 12, 2019, 1:31:48 PM
Hans, you still have to start SH3D via the starter we created. But no longer linking to the 1.5.2 script but to the SweetHome3D script.
Posted by hansmex at Feb 12, 2019, 2:27:47 PM
Thank you very much, UB, will give it a try!
Posted by UbuntuBirdy at Feb 13, 2019, 9:01:48 PM
After allmost 200h of developing parts, 3D-printing them, figure out if they work, redesign and reprint them (during the last 6 days...) I had now some time left to test FLE and as expected it now works like a dream - thanks to OpenGL 4.5 and higher!
Posted by UbuntuBirdy at Feb 14, 2019, 6:00:20 PM
Hans, if it still does not work for you, do not bother too much, because the performance of java3d1.6 is much worse than java3d1.5.2...
...wondering why...
