Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) |
| Print at Sep 27, 2026, 10:56:46 PM |
| Posted by YGYL at Sep 17, 2018, 1:03:23 PM |
Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)The length of objects such as railings or benches is not fixed. It is very painful to draw a suitable railing. There are several ways but they are not perfect 1Tensile deformation 2Exceeded part cannot be cut 3Tensile deformation It takes a new system to paint the railings easily. Pre-segmented dynamic object system!!!! Define parameters by changing part of the name in the model editing software After pre-segmenting the 3D model .After the user changes the length of the object, the model is combined by software calculation!!! The model is divided into 3 parts. Combine these parts according to different situations Combine these parts according to different situations Download the SH3D file on this web page |
| Posted by harbinger at Sep 17, 2018, 5:15:22 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) IDK if SH3D could ever do this, though i could see multiple uses for this concept — stairs, wall sections, windows sets, etc. Would take a lot of programming and testing. But i'd love to see this. |
| Posted by YGYL at Sep 18, 2018, 12:55:11 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) Another structure LAN_GAN2.sh3d ![]() |
| Posted by YGYL at Sep 18, 2018, 7:11:57 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) LAN_GAN3.sh3d ![]() |
| Posted by YGYL at Sep 20, 2018, 9:58:01 AM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) In this case, two new definitions, patterns and corners have been added. LAN_GAN4.sh3d ![]() |
| Posted by YGYL at Sep 20, 2018, 8:25:59 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)In complex situations, multiple patterns are required and the sequence ID number is used. LAN_GAN5.sh3d ![]() |
| Posted by YGYL at Sep 25, 2018, 4:11:37 AM |
Ceiling gypsum line includes internal corner and exposed corners Ceiling gypsum line includes internal corner and exposed corners download file Ceiling_gypsum_line.sh3d I hope WE can draw a line and calculate it automatically. |
| Posted by VeroniQ at Sep 25, 2018, 5:23:12 PM |
Re: Ceiling gypsum line includes internal corner and exposed corners Thank you, YGYL, for all these interesting models! |
| Posted by YGYL at Sep 26, 2018, 7:09:15 PM |
Re: Ceiling gypsum line includes internal corner and exposed cornersThank you, YGYL, for all these interesting models! Give Puybaret the material to test new functions. it takes a lot of time to do these things. |
| Posted by YGYL at Sep 26, 2018, 7:54:22 PM |
Luxurious ceiling gypsum line!!!!!Luxurious ceiling gypsum line Download the file Luxurious_ceiling_gypsum_line.sh3d Rendered graph Model component layout The whole object consists of small objects. Small objects consist of smaller objects. Smaller objects consist of the left and right sides of the component. The whole object seems to be encoded. The advantage is that it greatly reduces the disk footprint of files, whether they are furniture libraries or SH3D files. After encoding and subtracting edges, the current file is at least 10 times smaller than the original file.Luxurious_ceiling_gypsum_line.sh3d file size is only 3.2MB!!! It’s not for you to compress the file size of each piece of furniture to the limit, it is for you to support the user or the furniture library creator to split the compressed furniture. Without a good method of compressing file size, there will be no good furniture library, without a good furniture library, the user experience will not be good. I have said this before, the user's group furniture can be saved to the furniture library file. When you want to use it, just drag it from the furniture bar on the left side of the main interface to the floor plan. If you can dynamically create complex coded group objects, that's the best thing to do. I think a lot of professionals are going to use Sweet Home 3D. |
Current timezone is GMT Sep 27, 2026, 10:56:46 PM |
