Print at Oct 4, 2026, 11:33:49 AM
Posts: 16   Pages: 2   [ 1 2 | Next Page ]
Posted by hobbyrv at Feb 16, 2019, 12:45:05 PM
Photo-rendering failed
I finished a design and want to render it in 2nd best quality. This stops or doesn't start at all.
I already changed the pc to one with a better videocart, installed an older javaversion 8 192 (because I read that in one of the posts). It worked better for a while, but a next time it stops again, get a red cross (again).
I'm out of my means, please help me out. I have to present the design in a few days.
Posted by hobbyrv at Feb 16, 2019, 12:47:45 PM
Re: Photo-rendering failed
In addition: I also cut the design in 2, to see if less objects would work better.
Posted by Xiste at Feb 16, 2019, 7:07:21 PM
You are out of memory.
Follow this link:
http://www.sweethome3d.com/faq.jsp
Look at this section:
How can I adjust the memory used by Sweet Home 3D?
Posted by decasicko at Feb 27, 2019, 9:37:23 PM
Hello same problem here.
Updated JAva, even done Adjusting memory process, but i can't render photos. I have a good computer (I7 windows10 Radeon 4gb Card) but i can't.
I'm recovering an old project with was created and well rendered with my old Core 2 Duo....
Posted by Puybaret at Feb 28, 2019, 10:25:45 AM
If you're under Windows, do you use the 64 bit or 32 bit version of Sweet Home 3D (see About dialog box)? If you use the 32 bit version, try the 64 bit version by running the installer again and selecting the 64 bit architecture.
Posted by decasicko at Feb 28, 2019, 12:35:37 PM
Hello Emmanuel, i tried both Windows versions.
Also tried to reinstall JAva up to lastest version, but nothing change.
Maybe the problem is my computer (something is not working properly) or maybe the problem is my project (Very complex and started some years ago, and returned now.
Posted by hansmex at Feb 28, 2019, 12:49:15 PM
If y ou want, send me your file (or a link) and I'll have a look.
Posted by decasicko at Feb 28, 2019, 4:05:29 PM
Mi old project had lots of custom furnitures and textures, so i'm trying to delete everything, and sometimes works. But sometimes crash. So maybe it's about my project. If i made a new basic example, one room, one standard bed and one standard wardrobe, works well. So i will try where is the limit. I'll let you know.
Posted by hobbyrv at Mar 1, 2019, 12:28:34 PM
Adjusting the memory, as Xsite suggested, helped for me a small bit on my own pc. I borrowed another pc and where rendering was very slow or blocking first, by adjusting the memory it worked great, better than ever before. So I need a new pc to, or perhaps reinstall the old one.
Hansmex, if you find other options for improving this matter in the file of decasicko, will you publish it here? Thank you in advance.
Puybaret: how can I find the 'About dialog box'?
Posted by decasicko at Mar 4, 2019, 4:28:56 PM
Sent to Hansmex my files, to check if the problems are in my pc or in my files.
Thanks guy for your help!
