Print at Oct 4, 2026, 10:38:53 AM
Posts: 16   Pages: 2   [ Previous Page | 1 2 ]
Posted by decasicko at Mar 5, 2019, 11:50:43 AM
Re: Photo-rendering failed
After some PM with Hans, and checking Installing/Uninstalling some times Java and Sweethome3d, we determine, the problem is my computer.
I made a fresh install in a laptop and works fine. (Even modifying .ini file to adjust max memory), but my computer (I7 with W10 /16GB RAM/4GB graphic card) doesn't change, offering me maximum 0.4GB.
so maybe some software installed in my computer makes SH3H having incompatibility.
I will continue trying options in my computer, and until i find a solution, i will edit with my computer, and i will render with the laptop (Less powerful)
Posted by UbuntuBirdy at Mar 5, 2019, 12:04:38 PM
You're sure you have installed 64bit JAVA?
Posted by hansmex at Mar 5, 2019, 12:47:05 PM
The problem with decasicko is/was that he tried to render a 100MB file in 0.5 MB memory. He is now trying to increase memory allowance on his PC.
Posted by decasicko at Mar 5, 2019, 1:09:31 PM
Bu my computer doesn't let me more than 0.4Gb, although i have 16GB RAM.
I tested in other two computers and works fine, and memory allowance is good figures.
Something in my computer is not working well.
So, because is my problem, and not a program problem, i don't want to disturb.
If i reach a solution i will tell you in case somebody else share my problem.
Posted by Puybaret at Mar 5, 2019, 4:00:41 PM
Does the About dialog box show 32bit or 64bit?
Posted by decasicko at Mar 6, 2019, 9:48:16 AM
Hello all. SOLVED.
Finally using this video (https://www.youtube.com/watch?v=R3Hj83J0ekk), and Changing the value in the first step (I modify it with -XMX8g not delete) and now i start SH3D and i see:
Java version 1.8.0_202 - 64 bit - 0.1 / 7.1 GB
So finally it's working.
thanks a lot to all of us hwo helped me here or with Private Message.
so the problem was, my system was blocking any change of memory in JAVA restricting to 512MB.
