South Africa
Problem with File open
Ubuntu 12.04 precise SH3D 4.1
File open the files shown are from Home Folder clinking on any folder the correspondent files doesn’t show, the same happens on Furniture Import, Choose model. This was with SH3D 3.4 I replace to version 4.1 the same happens. Replace Java to version 1.6.0 still the same. Is there someone could help me with this to carry on with my project Thank you
Spain
Re: Problem with File open
Probably a silly question but... are you sure you have the permissions to list the content of these other directories?
---------------------------------------- If a long walk every day were healthy, mailmen would be immortal.
South Africa
I don’t understand the question. What permission is this? I dint know I need permission to open this files. This is in SH3D with the command Files. In Ubuntu I open files in very Folder. Can you please explain more on this. Thank you
Spain
I just meant the filesystem permissions for your user or group. If you can open files on another folders, with a file explorer for example, then you have the permissions. May be Java has not the correct permissions then?
As a workaround you can simply copy the file to your home folder, work on it and then, if needed, copy it back to the origin folder.
Luis,
The problem must lie with your computer. I'm using SH3D v4.1 with Ubuntu 12.04 and it works just fine.
HOWEVER... I had to change one thing: - uninstall IceTea Java - install Oracle (Sun) Java. After doing that, v4.0 and v4.1 worked fine.
There are a few small problems with version 4, but I'm not sure what is causing them. - Every now and then when a window pops up (e.g. Modify Walls), it doesn't display fully. I have to hit ESCAPE and give the same command. Usually then it works correctly. - A second problem is that when I have minimized the SH3D window, it doesn't restore correctly. Sometimes it pops up much smaller, sometimes half the window is blank.
@Emmanuel - There also seems to be an old problem that is re-appearing. When entering negative values, the cursor hangs after the first decimal digit. So, -0.45 comes out as -0.54. This problem existed long ago in version two-point-something (I think). I have to check whether it is easily reproducible.
South Africa
To hal9000 Thank you for the permission explanation. I don’t know how to enter permission in Java can you please help me. Thank you
hans,
My motherboard is Gygabyte GA-G41M-Combo CPU Pentium Dual core E5400 @ 2.70GHZ Memory 2 G Graphicard its VGA supports 3D I have Blender which I am learning (very difficult) I seen very high definition 3D figures with it. Ubuntu since 9.10 been working with this computer for 2 years with no problem of motherboard or any part of it and same with Windows Xp before. On my opinion the problem doesn’t come from the motherboard, unless some one points what can it be, just my opinion but it could be. Should I fill a Bug report? As always your feedback is appreciated. Thank you
Luis,
My computer is similar to yours, several years old, running Ubuntu since 8.10, I think.
With the introduction of SH3D v4.0, several people using Ubuntu, including myself, have had problems using the program. Until now, it seems everybody was able to solve their problem with the tip I gave you: uninstall IceTea Java, and install Sun Java. Check the messages on the forum....
South Africa
Hans,
I don’t know nothing about Java Before installation I was told it was unnecessary to uninstall IceTea, gave a site to install version 1.7 Find installed version.
luis@luis-G41M-Combo:~$ java -version java version "1.7.0_25" Java(TM) SE Runtime Environment (build 1.7.0_25-b15) Java HotSpot(TM) Server VM (build 23.25-b01, mixed mode) luis@luis-G41M-Combo:~$ Don’t know if IceTea still in System. After searching on the web for Sun Java found Java Runtime Environment 1.7.0.25 (32-bit) or Java JRE. Please let me know which is the correct one for SH3D. Thank you
South Africa
Hans,
From Software Center Icedtea Java Plugin – NOT onstalled Icedtea web control panel – Installed Icedtea Java web start – Installed In Synaptic found this Installed files properly from Software Center Icedtea. Icetea-netx-comon Icedtea-netx icedtea-6-jre-jamvm icedtea -6jre-cacao This files might interfering with SH3D. Thank you
