Previous Thread This topic has been viewed 3636 times and has 2 replies Next Thread
hassenius
Fail to print to PDF in Ubuntu 14.04
Hey,
Installed SweetHome3D from Ubuntu Repos.
When trying to print to PDF in Ubuntu 14.04 an empty PDF is generated.
When launching from command line, I can see this Java error:
java.lang.RuntimeException: java.awt.print.PrinterException: Width of printable area is too small.
at com.eteks.sweethome3d.swing.HomePrintableComponent.getPageCount(Unknown Source)
at com.eteks.sweethome3d.swing.HomePDFPrinter.write(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.printToPDF(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$43.call(Unknown Source)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.awt.print.PrinterException: Width of printable area is too small.
at javax.swing.TablePrintable.print(TablePrintable.java:214)
at com.eteks.sweethome3d.swing.FurnitureTable.print(Unknown Source)
at com.eteks.sweethome3d.swing.FurnitureTable.access$300(Unknown Source)
at com.eteks.sweethome3d.swing.FurnitureTable$12.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:302)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:733)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:703)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
I've tried updating the Java stuffs as suggested in FAQ re OffScreenSupport:
JAVA_ARGS="-Djava.library.path=/usr/lib/jni \
-Dcom.eteks.sweethome3d.applicationFolders=$HOME/.eteks/sweethome3d:/usr/share/sweethome3d \
-Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false"
No idea where to look next.
Any suggestions?
//hk
[Oct 13, 2014, 11:42:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Fail to print to PDF in Ubuntu 14.04
If setting a customized size paper with your own margins in page setup doesn't work, you could try to set the com.eteks.sweethome3d.swing.fixedPrintMargin property that was added in version 4.1. In SweetHome3D command line or your JAVA_ARGS var, simply add the option:
‑Dcom.eteks.sweethome3d.swing.fixedPrintMargin=0.2
for a 0.2 cm margin.
[Oct 14, 2014, 2:51:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hassenius
Sweet,
Went in and fiddled randomly with the page settings, and now it's generating the PDF no problem.
Don't actually think I changed anything, but happy it works now!
Thanks a mill!
[Oct 14, 2014, 9:51:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
