Download
Online
Gallery
Blog
Total posts in this thread: 34
Posts: 34   Pages: 4   [ 1 2 3 4 | Next Page ]
Previous Thread This topic has been viewed 13643 times and has 33 replies Next Thread
ALERT : Win10 build 1703
After download and installing new Win10 build 1703, I saw that sh3d crashed !
In opening, no problem.
I tryed to do a 'Save Under...' and bye...
No message...
When you re-try to open sh3d's file, do a simple 'Save' on a recuperated file, this resoluted the problem.
So, becareful !
====> 04-07-2017 - 15:21 GMT
1. Same crash when I want to import new model in existant project.
When I choose 'Furniture', 'Import furniture', 'choose model'........... CRASH ! similar to departure without saving.
2. Same thing on new project with an import.
Here is the latest log
devilish
Attachment hs_err_pid8328.log (44059 bytes) (Download count: 192)
[Edit 4 times, last edit by bdfd at Apr 8, 2017, 6:33:43 AM]
[Apr 7, 2017, 10:33:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: ALERT : Win10 build 1703
Today, same crash in saving on rendering picture... devilish
Here is the most recent log...
Attachment hs_err_pid14292.log (44583 bytes) (Download count: 189)
[Apr 8, 2017, 7:05:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
korner
Maybe, that's because of non-ASCII characters in folder name?
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.awt.shell.Win32ShellFolder2.getDisplayNameOf(JJI)Ljava/lang/String;+0
j sun.awt.shell.Win32ShellFolder2.access$1600(JJI)Ljava/lang/String;+4
j sun.awt.shell.Win32ShellFolder2$13.call()Ljava/lang/String;+15
j sun.awt.shell.Win32ShellFolder2$13.call()Ljava/lang/Object;+1
java_command: com.eteks.sweethome3d.SweetHome3D -open D:\SH3D\Crйations\06 Cubique\10\Cubique10 meublйe.sh3d
Sure this is a bug author needs to fix, but I can see a workaround in renaming that folder
[Apr 8, 2017, 10:06:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Good idea but LOST ! crying
Same crashes without french accents...
[Apr 8, 2017, 10:21:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fortunately, the option 'Save and compress' works fine !
[Apr 9, 2017, 8:23:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
@Manu : What are the news ?
[Apr 11, 2017, 7:49:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It looks like the Java bug #8170517 or #8173471. The first one was closed as non-reproducible and the second one was resolved recently but the fix is probably not published yet.
The bug must happen as soon as you try to access a file dialog box to choose a sh3d file or any other file handled by Sweet Home 3D, with a problem to access this file.
To cancel the directories that you used recently in Sweet Home 3D, run regedit, search for last/Directory# and last/Default/Directory in folders ending with com/eteks/sweethome3d and remove matching entries.
If it doesn't work better after that, try to move and open a Sweet Home 3D file in a very common place like your desktop to check if it works better or not.
[Apr 12, 2017, 9:54:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No change after remove all entries in "\HKEY_CURRENT_USER\Software\JavaSoft\Prefs\com\eteks\sweethome3d"... crying
Same crash with :
- Save Under
- choose new furniture
- save picture...
Why does it work with 'Save and compress' and NOT with 'Save' or 'Save as' ?
Another ideas ?
perhaps with java 1.9 ?
[Edit 2 times, last edit by bdfd at Apr 12, 2017, 12:33:41 PM]
[Apr 12, 2017, 11:04:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I just tried on a Windows 10 computer with Creator update (version 1703 / 15063.138), and didn't notice any issue.
You can try with Java 9 + Jar executable version for example, but keep in mind that Java 9 is still in Beta.
[Apr 12, 2017, 9:09:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
OK, we have same OS with the latest update (yesterday).
The link to download java9 is HERE cool
Here are the problems :
Java 9 is installed, After reboot I saw this :
Always in java 1.8 ! sick
So I saw a sub-directory jre8 in sh3d directory, I deleted it.
I launched sh3d and...
So I copied/pasted the jre-9 in programs directory into sh3d directory.
I deleted all plug-ins, same crashes... devilish
I desactived my anti-virus, same crashes... sick
Latest updates after win10 1703
here is the latest logs :
What can I do more ?
Even the soft "Furniture Library Editor" crashes... talk to the hand
see the last joined log.
Attachment hs_err_pid3352.log (41147 bytes) (Download count: 146)
Attachment hs_err_pid1572.log (41234 bytes) (Download count: 137)
Attachment hs_err_pid11088.log (41477 bytes) (Download count: 59)
Attachment hs_err_pid13688.log (26380 bytes) (Download count: 165)
[Edit 3 times, last edit by bdfd at Apr 13, 2017, 8:50:52 AM]
[Apr 13, 2017, 7:49:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
