applause High priority Roof with dormers and many corners and pitches // Dach mit Gauben und vielen Ecken und Neigungen
This topic has been viewed 7911 times and has 17 replies
Looking for a particular 3D model or texture? [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
shyne
Re: Roof with dormers and many corners and pitches // Dach mit Gauben und vielen Ecken und Neigungen
Post by shyne »
@Hansmex - I tried but I think I was really in geometry in school :D I get messed up in the 3D world. Anyway, I haven't taken time to test all those new possibilities. I think, I will get a good result.
@Keet As understood, there is no way in SH3D to make a whole into an object. I have to do this in another program
What you explained, will be a great help in some situations. But this time I meant, how can I find objects, which were made invisible. But now I am thinking, they still must be in the list in the bottom left corner. (and indeed they are)
So thank you for the great support.
Post by hansmex »
Check the Furniture List in the bottom left window. There are check marks on the last column...
shyne
Post by shyne »
Hi Hans,
I found them, thank you :)
https://workupload.com/file/ELhVMSQbv38
Now I have experimented with the roof parts. It looks quite good. The angle in the "ridge" is now wrong because I inserted the dormers at the ends. But that would be OK. However, I can only change the size if I keep the proportions and then it doesn't fit on my surface anymore. Ideas?
Ideally, the ridge would also be pointed, but I would have the dormers at the ends...
shyne
Post by shyne »
https://workupload.com/file/duGWm2HAgxb
I did the following, resize the rood without the middle part (doesn't bother about proportions)... then add the middle part. I had to manipulate the height and so on and I am not sure, wether this is the best method, but hey, it 's a little bit more similar to what I needed...
Post by hansmex »
Looks like a nice roof.
I hope my tips were useful?
If you need more help, just ask.
And share the design file....😃
shyne
Post by shyne »
Yes, you were great help! Absolutely! Here is the roof: https://workupload.com/file/DgM5yagGStX The parts don`t fir perfectly but for me it works :)
shyne
Post by shyne »
(This website won't keep the files for very long)
Post by dorin »
This is what I've done in few hours. Of course it is more to work.
And HERE is the file (my vision)
