High priority Camera Data Generator v1.1
This topic has been viewed 7856 times and has 17 replies
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Xlance
Camera Data Generator v1.1n Fixed
Post by Xlance »
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
Re: Camera Data Generator v1.1n Fixed
Post by dorin »
Now it works OK.
The calendar AND the csv output.
Problem:
I steel receive some errors:
java.lang.ClassNotFoundException: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
at AdvancedCameraDataGenerator.<init>(AdvancedCameraDataGenerator.java:148)
Probably you could find a better solution.
Like to find first what LaF are provided by the local OS.
Xlance
Camera Data Generator v1.1p
Post by Xlance »
Hello :-)
+ Added a multi stage Fallback Mechanism for selecting look and feel of the UI, the program will:
Check first if OS is Mac or not,
if yes > apply MacOS LookAndFeel
if not > will detect installed LookAndFeels > apply system default
if failed > apply Cross Platform LookAndFeel
if failed > apply Metal LookAndFeel
+ Added junit.jar which was missing
https://www.mediafire.com/file/mycx02vm ... p.jar/file
Cheers
Re: Camera Data Generator v1.1p
Post by dorin »
Now it appear to works correctly. [=D>]
I think this could be the final 1.1.
One more suggestion (but not mandatory):
When click OK -> close (exit) the application.
You've made a very good job!
PS (also not mandatory)
You could put cityCoordinates and timeZoneOffsets in two text files and loaded from there.
In this way the main program will be more easy to read.
Xlance
Export CAD to SH3D
Post by Xlance »
@Dorin and Everyone
Take a look at this brand new plugin :-)
https://sourceforge.net/p/sweethome3d/plug-ins/56/
z56oo
Country: France
Post by z56oo »
It appears on the generation of an elliptical path that for the intermediate points there is an inaccuracy between the position of the point and the given Fov
z56oo
Country: France
Post by z56oo »
Sorry replace in my previous message Fov by Yaw
Xlance
Camera Data Generator v1.1Q
Post by Xlance »
Hello [:)]
Added a new function / checkbox to switch CSV separator from ( , ) to ( ; ) for Euro OS
Note:
CameraBagPlugin-1.8 plugin now supports importing CSV files with ( ; ) separator
https://sourceforge.net/p/sweethome3d/p ... r-1.1Q.jar
