Unable to store POV
This topic has been viewed 46541 times and has 13 replies
Re: Unable to store POV
kiliansanches = AI generated rubbish
Jamesorter
This technical snag echoes a personal frustration with a particular open-source video editor. I was crafting a travel vlog, meticulously arranging clips, only for the Connections Game equivalent of an export error to repeatedly obliterate my carefully constructed sequence.
UstinovBykova
I ran into the same POV issue before, and what worked for me was locking the viewport before saving the view, then using 'View > Align View > Save View' and typing the exact camera coordinates manually in the N panel instead of relying only on saved views. Rendering 40-50 images is tedious, so I'd take short breaks playing Slope Unblocked between batch renders to stay sane. Good luck with the floorplan, it looks like a great project!
It's frustrating when a feature doesn't work as expected, especially when you're trying to achieve a specific visual outcome! While I haven't personally used Home Assistant's floorplan feature, I've had similar experiences in other creative platforms. When I'm working on levels in Geometry Dash and need consistent camera angles for different sections, I often find that manually inputting the exact coordinates for the camera can provide the precision I need. Perhaps there's a way to manually adjust or save camera positions with numerical values in Home Assistant, similar to how it's done in Geometry Dash, which might give you the consistency you're looking for!
