Quite a few 3D warehouse models can be downloaded in .KMZ format (aka Google Earth), these are in fact zipped .DAE files and can be imported directly in SH3D (latest versions). Which saves you the bother of using Sketchup to convert.
To add ceiling lights, the easiest is just to place (carefully) light-sources from the catalogue near/over/under the model (.DAE/.OBJ will not include light-source properties). You can add light-source properties to your models in a SH3D FurnitureLibraryEditor file - see for instance thread 5206.
PS Unless you prefer the language of Goethe, you may want to skip the language option in the above URL, by just using https://3dwarehouse.sketchup.com/ - or to change the language to Shakespeare: https://3dwarehouse.sketchup.com/?hl=en
my SH3D project
This topic has been viewed 18317 times and has 10 replies
