VERY slow video rendering
This topic has been viewed 34470 times and has 19 replies
elvishome
Country: United Arab Emirates
Re: VERY slow video rendering
Post by elvishome »
I suggest you to create clips( a very small rendered part of the 3D view), later mix all the clips in any video editing application.
marcop300
Country: United States
Post by marcop300 »
wow.. that is a long item to render. i would bet if you had a i7 PC, more RAM, and a larger GPU card and a SSD HD's it would go a lot faster. if you want I can test it on my PC. and even do a Webex with you to show you how fast it will take. let me know. can I ask what you are drawing that take that much CPU? i bet it is a awesome pic
Wiebenor
Post by Wiebenor »
So... Does anyone have any idea what this app was designed to render with??? What I mean is that some apps use GPU to render, while others use CPU, and still others use both equally good or bad, as the case might be, so which category is this app??? Was thinking about building a computer just for renders with this, but after seeing people with extra fast setups having the same problem as me, maybe I shouldn't... A 30 second video takes me at least 3 days to render, and that's with the whole 8ft X 17ft room filled with stuff on one wall, and LED lights on the top of the walls... Anyone, perhaps the author, know the answers???
Country: UK
Post by Mike53 »
@Wiebenor try HERE for more info.
kaneelschep
Country: Holland
Post by kaneelschep »
HI all. Its now mid 2022 and GPU Hardware rendering has become the main thing. It would make rendering the video's a LOT faster. Is this something to be expected in sweet home 3d? Thanks!
Country: Paris, France
Post by Puybaret »
Try YafaRay renderer in the new version 7.0, but don't expect Sweet Home 3D to be able to use GPU for rendering soon.
stef.salmon
Country: UK
Post by stef.salmon »
I've been using the YafaRay engine for sometime and now all of a sudden what used to take 4 minutes to render a fairly simple floor layout, is taking nearly 18 minutes. I have now idea why!
Any ideas, would be much appreciated.
Thanks.
Post by Puybaret »
Did you try to simply relaunch Sweet Home 3D?
Maybe a part of the memory used by YafaRay is not freed after each rendering and the program starts to miss RAM.
stef.salmon
Country: UK
I shut it down in task manager and all seems to be OK now.
Thanks [:)]
Country: France
Post by VeroniQ »
Hi everybody,
Maybe you will be interested by this new tutorial on Sweet Home 3D Youtube channel about making and editing a video, with some tricks to do it "rather" quickly.
Users browsing this forum: Amazon [Bot]
