Sweet Home 3D 4.0
This topic has been viewed 307671 times and has 136 replies
m@
Re: Sweet Home 3D 4.0
Post by m@ »
It seems that the fields to enter width and depth of furniture where mixed up; with changes the depth and vice versa (happens in the import dialog as well as in the modify dialog, so at least the behavior is constant). I tested with several objects from several sources, the behavior is always the same. It's not a big problem, but maybe you still want to fix it in the next release. [:)]
Country: Paris, France
Post by Puybaret »
m@, I didn't succeed to reproduce your issue. [:(]
Maybe there's an other condition...
m@
Post by m@ »
Hi Emmanuel
I checked again and found out that the confusion between width and depth only happens with some models, with some other not. Therefore, the problem seems to origin in the models and not in your software. Sorry for bothering you about that!
BLAlley
Post by BLAlley »
Updated to 4.0, now I can't render advanced photos. How to I go back to the less buggy version?
Post by Puybaret »
As explained in the Download page, all released versions can be found at http://sourceforge.net/projects/sweetho ... eetHome3D/
By the way, it would be nice to explain why you can't render photos. Jumping to previous versions won't help to fix bugs if you found one.
Yuri_fromBY
Country: Belarus
Post by Yuri_fromBY »
I have a problem - on Ubuntu 13.04 start FILE-Preferences crashes.
Post by hansmex »
Some suggestions:
1 - Read the FAQ
2 - Throw out IceTea Java and replace with Sun Java. This has helped many people using 12.04; good guess it may work in 13.04.
