Furniture Library Editor released
This topic has been viewed 3013550 times and has 252 replies
Country: Paris, France
Re: Furniture Library Editor released
Post by Puybaret »
There's no separated version history for the Furniture Library Editor. The version 1.28 only brought some icon changes.
enkonyito
Post by enkonyito »
For building the FurnitureLibraryEditor-version.jar file with the furnitureLibraryEditorJarExecutable target, the Color button does not open any panel and displays this message in the command prompt:
Code: Select all
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: input == null!
        at javax.imageio.ImageIO.read(Unknown Source)
        at com.eteks.sweethome3d.swing.SwingTools.createCustomCursor(Unknown Source)
        at com.eteks.sweethome3d.swing.ColorButton$RecentColorsPanel.<init>(Unknown Source)
        at com.eteks.sweethome3d.swing.ColorButton.createColorChooser(Unknown Source)
        at com.eteks.sweethome3d.swing.ColorButton.access$300(Unknown Source)
        at com.eteks.sweethome3d.swing.ColorButton$2.actionPerformed(Unknown Source)
        at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$ModelLightSourcesPanel.displayView(Unknown Source)
        at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$1.actionPerformed(Unknown Source)
        at com.eteks.sweethome3d.swing.SwingTools.showOptionDialog(Unknown Source)
        at com.eteks.sweethome3d.swing.SwingTools.showConfirmDialog(Unknown Source)
        at com.eteks.furniturelibraryeditor.swing.FurniturePanel.displayView(Unknown Source)
        at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureController.displayView(Unknown Source)
        at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureLibraryController.modifySelectedFurniture(Unknown Source)
        at com.eteks.furniturelibraryeditor.swing.FurnitureLibraryTable$3.mouseClicked(Unknown Source)
In Eclipse, the Color button opens the color modification panel.
EnkoNyito
Post by Puybaret »
Many files of Sweet Home 3D are excluded from the JAR executable file of the Furniture Library Editor, to build a JAR file as small as possible.
If you change the features of the editor, you'll have to check which files you should not exclude anymore. In your case, I guess you need the [font=courier new]pipette[/font] cursor icons found in com/eteks/sweethome3d/swing/resources/cursors folder.
enkonyito
Post by enkonyito »
Indeed, the problem is solved by including the [font=courier new]pipette[/font] cursor icons.
Here is the derived version that allows to create lights and modify their sources.
FurnitureLibraryEditor-1.28_derived.jar
FurnitureLibraryEditor-1.28-src_derived.zip
Note: As it is not possible to attach the files because apparently their sizes exceed the maximum allowed, I put links to SourceForge.
EnkoNyito
harbinger
Country: Clearwater, FL, US
Post by harbinger »
The derived version works well, but i'm leery of those icons. Yuk!
Would be great if the light editor would draw where the light source is in relation to the model, using the XYZ we enter. I love the fact that i can adjust the color right there!
enkonyito
Post by enkonyito »
@harbinger
The standard version of the FurnitureLibraryEditor-1.28 tool uses the new icons of Sweet Home 3D 6.6 .
It would be interesting but this problem does not yet have a solution.
EnkoNyito
davidzhghenti
Country: Georgia
Post by davidzhghenti »
Good day all..
I download this program... In YouTube I saw Up panel is "Tools". near the File, EDIT, Plan, Help. in this How I add "TOOL"?
thanks,,,
Post by Puybaret »
I don’t know what you saw but the Furniture Library Editor is a separated application as explained in the first message of this thread.
enkonyito
Post by enkonyito »
FurnitureLibraryEditor-1.28.1_derived
  • added light sources 3D preview (transparent light, opaque source)
executable jar
source code
EnkoNyito
Andrew_Somovo
Country: Russia
Post by Andrew_Somovo »
Hello! I would really like it to be possible to edit and save the price in the FurnitureLibraryEditor, so that when importing in the library, the price is linked to the model! Is there a way to do this? Our company is ready to pay for it, how much will it cost?
