Sweet Home 3D 6.0
This topic has been viewed 1212135 times and has 196 replies
Country: Paris, France
Re: Sweet Home 3D 6.0
Post by Puybaret »
What makes you think it's because of the version 6.0? Under what system do you use Sweet Home 3D? What error do you get?
Jerintho
Country: Hongarije
Post by Jerintho »
I was first using version 5.7 without any problems (Windows 10 system). After updating to version 6.0, the program crashes as I try to save my drawing. After going back to 5.7 everything works great again...
I will try to uninstall first and re-install 6.0. I hope it will be fixed then.
By the way, love your stuff!!
Jerintho
Country: Hongarije
Post by Jerintho »
Made a fresh install, everything works great now!
Post by dorin »
WARNING For those who usually modify the look and feel.
Same features of the v.6.0 may not work because of this.
E.G.
I use
Code: Select all
-Dswing.defaultlaf=javax.swing.plaf.nimbus.NimbusLookAndFeel
With this option the math formula in number box are not processed.
Without this (original file) it work perfect.
Raevlav
Country: Rus
Post by Raevlav »
sorry guys if this is not the proper topic or these problems have been already discussed.
After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons.
Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
Kunda
Post by Kunda »
@dorin can you provide a screenshot of what the end result of modifying the look-and-feel of SH3D looks like ?
Post by dorin »
Is not a big deal only look a little bit better
The standard:
The nimbus:
Remember the Warning: with this look-and-feel setting some function DON'T work. I've discover at this moment only the math formula issue but could be more other.
maureenowaters
Country: USA
Post by maureenowaters »
So beautiful, just love it.
3DMR
Country: Nederland
Post by 3DMR »
Hi Puybaret, I managed to open and close a door with Blender.
In SweetHome I can now see the option (Modify opening) but the textures of the door and hinges are transparent after exporting them (OBJ) from Blender.
(The door frame is not transparent).
What should I do to make the textures solid ?
3DMR
Country: Nederland
Post by 3DMR »
Hi Puybaret, Found it and I'm a little embarrassed, I forgot to look at the "normals" in Blender, they weren't all facing out. Sloppy of me but maybe someone else can benefit from the "solution".
